pikapower1998
Member
- Joined
- Jul 6, 2014
- Messages
- 8
So I have this Maytag WU400 undercounter dishwasher which was manufactured in August of 1973. recently it started to have a lot of problems all at once. The first noticeable is issue is the fill valve which wont open sometimes, I found out the issue is either the pressure switch or the timer. I cant figure out which one because my multimeter is missing. The next problem was the original maytag door spring snapping, I managed to retrofit a modern whirlpool spring into it which solved the problem, however, I would still like to have an original spring. Onto the next issue. The machine is using the all the original parts from the day it was built, so the crusty old door gasket started leaked, or so I think, The vent cover on the inside of the machine was shattered by some menacing kids. I quickly cut out a new one from some aluminum to prevent water from leaking out. could it be possible that water is leaking around that, going through the inside of the door, and simulating a door gasket leak? I guess I'll have to run the machine without the front panel to find out. If it is the door gasket, Is there any way I can fix the leak without replacing the gasket? It is a very minor leak with about 1 tiny drop every 3 minutes onto the lower access panel. And onto the final issue: The lower spray arm has always been "bent". not the actual spray arm, and not the metal shaft. but one end of the spray arm is more raised than the other. after I took the spray arm bearing out for the first time, I noticed that the plastic bearing seemed to be at an angle and off center. Is this a manufacturing error? the plastic doesn't seem warped. And it's been like this since I moved in. The main issue with this is that if the spary arm is facing the door when you close it, it hits the spray arm and it gets caught by the door. I don't want to get a new machine because of how well this machine has served us over the years. I took care of it, however the previous owners abused the hell out of it.
