Maytag Suds Saver Help!!!!
utjj99
Feb 25, 2006
54
I just got a new suds saver hose so I hooked it up and bad news. Even with the switch set for "save suds" it drains out of the main hose which is suppose to be in the stand pipe. When I set it to "return suds" the machine sucks through the stand pipe hose again and not the suds return hose. Any tips or things I should be looking at to fix this problem? Any help would be wonderful!
Sounds like a bad suds return solenoid/diverter valve to me. Do you hear a loud "BANG" when set for "Save Suds" or the "Suds Return" setting?
westy
No I don't hear any noise when I set it to save suds! Should I? Where is the diverter valve? Are they still available? Easy to fix?
Pump!
Should there be two seperate hoses going from the pump to the two seperate exit hoses. I see the problem now. I believe what has happened was at some time in the past the pump went bad and instead of spending the extra money and buying the right pump they bought one for a none suds saving model. They removed the hose that connects the pump to the suds return hose because there was no longer a nipple to hook it to and then cut the wires to the solenoid diverter. Is the right pump still available? Does anyone has a spare? I'm not sure if it is worth trying to fix this though I really have always wanted a suds saver model.
Nope, almost right, though.
The pump has one hose from the tub leading into it, and one hose leading out. The out hose should go to the diverter valve. Then there should be two hoses from the diverty valve - one to the normal drain hose, the other to the suds saver hose.
The diverter valve will divert the pump output (and input) to either the drain hose or the suds save hose, but not both at once. The washer motor will reverse for suds saving and the pump works equally well forwards or backwards. Forwards, it drains. Backwards, it sucks. It's always going, even when agitating. It's just the various valves that direct it to pump out, pump in, or do nothing at all.
Here's a photo of the original working pump on my A606S:
All you may *need* to do is to reconnect the leads to the diverter valve - it may still work - and then you'll be suds saving again.
Some repair people liked to disconnect suds saving devices because it was one less thing to break down or result in a service call for no reason. Maybe the previous owner didn't want two drain hoses, no room in the standpipe. Who knows? The thing to do is to experiment (safely) with it, or find someone who will do it for you.
In any case, I think you can see why repair people didn't like suds savers. The diverter valve is way in the back of the cabinet. It's hard to simply get a good photo of, let alone get at for troubleshooting/repair/replacement. Maytag washers were otherwise known for their ease of service - both the motor and pump are right up front, and can be serviced without even having to move the machine. And the belts can be replaced by simply moving the machine a foot or two from the wall, and tilting it back (and maybe removing the belt guard if any). The diverter valve looks like it would require some contortions and scraped knuckles to get at.
John has a Maytag 140S, which has a slightly different suds diverter valve than the standard one found in most Maytags. His would be a 4 port diverter, with a built in suds pump and motor. Im not sure of the hose routing but it does connect slightly different than the standard 3 port diverters. Perhaps another club member can help John with the hose routing.......
