g3bill
So, the Maytag washer is well over 20 years old and hasn't caused many problems over the years. The timer was getting stiff, maybe 8-12 months ago, so sprayed some silicone in the gear and contact unit, worked great and easy till lately. Tonight it stopped cycling I think, I know it got hard to turn past an area on the dial. It was washing but turned it off then turned the dial where it should be and wouldn't start in any position, there was power getting to the timer. Anyway removed the timer unit and a spring fell from the ratchet levers and hard to figure getting it back in. I still need to remove the pin on dial shaft to seperate and repair damage but just wanted to get this info soon as possible to get it running in a couple days hopefully. I think the twisted end of the spring might go in the black casting in corner, will post pic if can. Tx, Bill
Theres a number on the timer as stamped by maytag 2-05637 ?
