maytag washer
maytag31
Dec 6, 2023
OCEANSIDE CA.
Hi i have a 31 year old maytag washer model #lat5910aaw looking for some ideas whats wrong with it. This is what its doing wont agitate unless you add tension to motor> This is what i replaced both belts,the motor guides and springs and it worked a few times after that.Now when i went to use it it was burning the belt and wont agitate if i add tension on motor it would shut off.I tryed it later and added some tension and got it to work, it seems after i get it to work it will keep working load after load like it needs to warm up its inside my house so its in 65-70 degrees temp . I was thinking maybe the oil in the trans needs to be replaced? anybody have any ideas thanks Jack
maytag not agitating sometimes
Hi i just tried the washer it seems if i use it the next day it will work ok not sure what that has to do with anything any ideas? thanks Jack
