Maytag Wringer Gooseneck
bingwsguy
Feb 8, 2006
252
Binghamton NY
Does anyone have a Gooseneck and the fitting which screws onto the drain hose of a Maytag Wringer Washer that they would be willing to sell? You can e mail me directly. Thank You, Joe
Joe, If you do not find the metal gooseneck, it would be possible to use a short length of hose with a female coupling and one of the plastic gooseneck brackets used on some newer washers to form the gooseneck bend at the end of the straight drain hose so that it hangs in the stand pipe or over the side of the tub or sink. Please do not feel that I am insulting your desire for the original part, just offering a way for you to be able to use the pump until you find the part you want.
Tom
Hey Joe
It's in the mail. Good luck with it. Didn't like the Maytag hose: too high up in the air, way too short, hard to pull off its latch, so I replaced it, but saved the old one. You can see the replacement in the second part of the video.
