tarantulae
Active member
Picked up a maytag wringer washer off craigslist today with the intention of using it for cloth diapers for my daughter who is just over a month old.
I read quite a few threads on here, and knew what I was looking for, but it was free, and "worked" so hard to argue. It has a lot of rust, and at first the motor stalled when I plugged it in. I realized the wringer was stalling it out, and after moving it around some, it was able to run.
The wringers are stuck turning in one direction, no matter which way the lever is pointed (at wringer, away from wringer, toward tub, away from tub).
I felt pretty good about diving into it to try to find what was seized up or causing the selector to not function. I took the wringer apart, and seperated the lower half from the drive head. The grease or oil that had been in there was solidified in a pancake at the bottom, with dry crusty bits along the bevel gears.
I'm in the process of cleaning it out, but wanted to know what kind of grease or oil to replace once I have the rust and gunk cleaned out. I read somewhere the wringer head gets 1/2 lb of some kind of heavy grease, while the lower transmission for the agitator takes something like transmission fluid.
I do plan to remove the lower transmission as well and replace the seal to the tub, as I suspect that failed, causing water to fill the transmission and oil to leak out. The back left leg is caked in oil. I'd like to know how much to refill the transmission with, what weight, and what to fill the wringer head with.
For gaskets, can I use RTV silicone when i reseat the wringer head? Is there an off the shelf seal that will work for the tub seal?
Thank you for any advice, I will work on getting some pictures tomorrow with daylight. I'd post the CL pictures but he was quick in taking the post down and I didn't think to save them in advance.
