turquoisedude
This is hard to admit, but there are times when I just can't leave well enough alone... Not long after I got the Westy Laundromat back up and running, I noticed some weirdness with the water solenoids. Hot water would trickle into the tub at the end of the cycle - if I turned the timer to the Medium temperature selection and stopped and started the machine 2 or 3 times, the trickle would stop. The manual suggested cleaning out the solenoid, which made sense. I should have resisted the urge to tinker...
I took that darn solenoid apart and cleaned it, when I put it back together, cold water wouldn't flow... I dropped the solenoid into a bucket of water while it was powered up and freaked out. I dried it out, cleaned it again and retested it. Still inconsistent cold water flow... This was at the end of November, so I gave up. I wasn't back down in Ogden until this weekend, but I was armed with a new solenoid!
