Meet our new Miele W1!
adamthemieleman
Sep 28, 2013
76
York
Hello all, I've been quiet on the forum lately, largely due to work and personal issues at home.
However I'm making a return with the best way I know!
We've upgraded our Miele with guess what, another Miele!
We had this WKG120 at my work (John Lewis). It was an ex display which we needed to get rid of as it was no longer ranged, but it had a slight electrical fault, (it wouldn't switch on)
Miele came out and fixed it and updated it while they were out.
So an ex display ex repair Miele W1 all ours for a grand total of £400! This is a machine that normally retails for £1k!
On top of that we get the free years worth supply of twindos and the 5 year guarantee.
It's currently doing its 'calibration' wash. I have some rather grubby work shirts to test it with, including one shirt which has two stains side by side. I have no idea what it is, but nothing has shifted it.
I like Miele and I know they're good, but I don't have high expectations for the twindos or the steam smoothing.
Here's some photos
Well...
Turns out, we need an engineer visit already! As this was a demonstration machine, it had the cartridges preinstalled on delivery, and guess what, the dispensing didn't work! I assume the tubes are blocked. The machine is also vibrating excessively, despite being perfectly level. The old one didn't do that!
Still early days, but a bit disenchanted at the moment.
I'll keep you all updated
The first generation W1s (and T1s for that matter) had a lot of smaller issues (vibrations, bad wash&#92rinse results). But given yours has the calibration cycle already. it should be of a later revision.
There should be a cleaning cycle for the dosage system, but you'd need the empty cartridges you can fill your self for that.
Cartridges
Are there any sealant tabs still in place on the cartridges? (You know, like the tabs on tomato ketchup squeezy bottles, or the foils on 3-in-1 carpet shampoo).
Perhaps the pipework requires to be manually primed?
Twindos Cartridges
The twindos cartridges have rubber ends that you remove. At the end of the cartridges are spring mounted rubber bungs that move in and out when you insert and remove the cartridges they open and seal the cartridges.
If the machine has been stood for a long period of time the liquid inside of the twindos system will become thick and will require an engineer visit to flush the system out so its able to be used again
Thanks for the info.
I presumed that the machine being ex-display, that the twin-dos had never actually previously been used, and merely thought the cartridges had been placed into the slots (with sealing caps still in place), for demonstration purposes only.
Yes, as it was ex demo, the cartridges were already inside and have been for a few months. We're also experiencing bad vibration, I realised it wasn't dispensing for the shorts wash so did a spin. We've had a Miele before which was smooth and hardly moved, I know this is faster and potentially heavier but nothing to make the vibration it was doing.
The calibration wash went well, very smooth and quiet, but I'm not sure it hit 90, as the door didn't feel hot. Perhaps it's not supposed to.
I must admit though, Miele were great over the phone. The engineer comes Tuesday so hopefully he can fix both issues. They even told us the voucher codes to redeem the supply of twindos, as the voucher had been lost.
I'll keep the thread updated with any twists and turns..
MieleUSA hasn't had a new washer model added to the line up since the 30XX series a few years ago. Though there have been "upgrades" they are due for something new.
My guess is one big issue is to decide if a version of the W1 does come to this side of the pond should it be 120v or 220v.
Since it seems MieleUSA has all but given up on 220v for domestic washers outside of the "professional" side such as the Little Giants for the USA market, will be interesting to see what if anything happens with W1 units.
Though gaining some market share
In large part for urban areas and other construction where vented dryers are not possible, any sort of condenser dryer is still a hard sell for much of the USA.
Here in NYC you are seeing more condenser dryers or any sort (heat pump and so forth) due to new construction and or redevelopment of former commercial space. In either case access to outside facing walls is at a premium. Also much new construction is glass façade instead of masonry walls, thus again venting a dryer would be difficult to impossible.
Running a dryer for two hours or so just isn't up a large part of American's laundry habits. What with washers (front loaders) now taking one and a half to two hours (or more) to complete a load, asking some to endure another two hours for drying time is more than some will bear. You're talking about between four to five hours just to one load of washing.
For those where such economical "green" or whatever appliances are up their street, fair enough. But those having grown used to the speed and ease of electric or gas vented dryers may and likely will balk.
One saving grace with heat pump dryers is they can be used in temperate climates such as NYC during the warmer and humid times of year. Once temps go above say 75F and humidity kicks in (for which NYS summers are famous), my Lavatherm dryer is almost totally useless. Only way to run the thing is to also turn on the air conditioner, which to my mind is a foolish waste of money.
"my Lavatherm dryer is almost totally useless"
Is it a standard condenser type, by any chance?
I have a condenser Zanussi dryer which works wonderfully in the cold winter breezes.
However, still/muggy summer heat it does not like, and laundry takes forever to dry, virtually baking in the machine. You can smell the heat.
I am actually tempted to go back to a sensible vented 'hose-out-the-window' dryer.
Yes, Lavatherm 57700
Owner's manual claims the thing can be used to a "permissible ambient" temperature of 35°C (95F), but I've never been too sure.
Once outdoor temps reach 75F or above and thus indoor aren't much less (without turning on the AC), the thing is useless. Better to dry things by hanging them on a maiden or horse. Indeed if one turns on a fan they will dry faster than in the Lavatherm.
During cooler or cold times of the year, things are more tolerable. There times are as listed above in previous post.
Knowing in advance how the filter system on this model of Lavatherm isn't the best, tend not to do towels and things that give off much lint. Still am sure sooner or later the thing will need to be opened for a full cleaning.
If one didn't have the Lavatherm would consider a Miele or other heat pump dryer. After all either way would be looking at drying times in excess of one and one half hours.
Warm and muggy weather NYC has in spades during late Spring through much of the Fall, hence why the Lavatherm is useless to one for much of the year.
" am actually tempted to go back to a sensible vented 'hose-out-the-window dryer."
Yes, that is why we keep the small Whirlpool compact/portable vented dryer. Though have jigged up a window vent (bit of wood with a hole sawed out), so don't have to hang the hose out of window.
It actually is the best of both worlds. In deep Winter when the Whirlpool vented dryer spews out telltale plumes of steam (a dead giveaway that a clothes dryer is being used), can switch to the Lavatherm. Not only does the latter dry one's washing, but adds some heat and moisture back into the room. Most welcomed with the dry conditions from steam radiator heating.
Disadvantages
Condenser machines are good for placing almost anywhere, but they need the proper temperature differential in order to work properly; i.e. cool ventilation.
Vented machines need the hose and window or duct.
Heatpump condensers don't have the above disadvantages, but they have other disadvantages of their own - long drying times, and susceptibility to clogged heat-exchanger/heatpump.
Decisions, decisions.
All fixed!
After two engineer visits later, we're all up and running. The second engineer apparently removed the filter, to allow water to come out. Doing this managed to prime the tubes. It sounds like there was just an airlock because it hadn't been used for some time.
Mum noticed after it had been fixed that it hadn't cleaned the towels well. I looked at the settings and the engineer must have changed the doses, they were low, very low. U1 was 30ml and U2 was around 20ml. Needless to say I've adjusted it, to double which is what it was before.
I can definitely see suds! We'll see how it goes
The only issue I've had with TwinDos was with a failed cartridge that had an airlock due to a faulty valve.
You can flush the twin-dos system yourself by just following the on-screen instructions in the setup menu for cleaning it.
The main thing is if you are using thicker detergents, or if you change detergent you definitely need to perform a flush out. The Miele ultra phase packs are designed to be pumped, so aren't viscous.
A lot of the normal ones are designed to cling to clothes when you're pre-treating so they're not actually very ideal for pumping.
Ariel liquid is probably runnier than Persil Small and Mighty though.
If you want to use Persil, I'd suggest getting your hands on some Persil Professional Bio liquid, not the consumer version. It comes in a huge 10 L tank!
https://www.amazon.co.uk/d/Laundry-Supplies/Diversey-Persil-Professional-Auto-Dose-Liquid/B00L8PEG42
Miele UltraPhase
Could you re-use* the Miele disposable UltraPhase detergent bottles, by boring a hole on the upper side, pouring in your preferred liquid, then putting a rubber bung in? Or is there a fill hole covered over? I presume there is some kind of air vent or bleed hole to allow air into the bottle to prevent airlock and the bottle collapsing due to vacuum pressure.
*{As you might do with ink-jet printer cartidges...}
240V washers in the US
O! Ye stars and little fishies!
Please!
I had forgotten how awful this low-voltage system was when it comes to running anything more potent than a tea-cup stirrer.
Because Americans think their ways are better than the rest of the world, we are stuck with the English Common system of measurement (14 inches to foot, four feet to a quart, three quarts to a tablespoon...and everything measured by volume).
Same reason we are stuck with this stupid 120V 15A (20A if you're lucky) current.
Never mind the resistance to all the other advances Europe and Asia take for granted.
Spare cartridges
I think the Original Poster's machine came from 'off-the-floor', end-of-line, display model, without all the usual odds and ends a pristine packaged model would have.
"14 inches to foot"
Eh?
Isn't it 12" to a foot?
I have seen a foot ruler divided into 10ths though. I don't if it was a genuine American device, or if it was a joke one that somebody picked up on holiday somewhere.
Rolls.....
I was teasing. Robert Heinlein made that particular joke first, in The Moon is a Harsh Mistress, but it is nuts here in the US.
I still do all my own work and layouts in metric - so much easier than this stupid system my American colleagues use. Faster, more accurate, scalable....
I need to start adding /snark to my posts.
With all the different detergents I use from load to load, from what I can see the auto dosing units wouldnt work as well for me as a regular unit with a drawer.
Cool and easy if you use the same detergent a lot, but otherwise purging and cleaning lines to go from one to the other with frequency seems like it would become a chore and wasteful as you lose the product in the lines.
Or am I not understanding how this works?
UD
Auto dose Persil calculation
The dose for that Unilever Persil is only usually 35ml.
It should last 285 washes and can be purchased for about €70 if you shop around.
24 cent per wash.
Like the Miele stuff, it's specifically designed to be pumped by dosing system. So if shouldn't clog .
You still have a drawer.
Choice is :
1. Use the washing machine as normal - with the drawer.
2. Press DOS and the machine will dispense it's own detergent - you can select colour or whites which adds a dose of peroxide bleach. You can also pick light (lower dose), normal or heavy (does a full prewash).
Then you can either buy Miele cartridges ready filled, or you can use your own liquid in refillable containers.
You can either use a universal detergent on its own or with a softener in the second tank.
You could also use your own detergent and a liquid wash booster I'm cartridge 2.
So LOTS of options and you can always just dose.manually by simply not selecting DOS.
