tomwasher81
Member
I am looking for some advice. I have a Miele G6860 sci Dishwasher (UK model). I purchased it in March 2019, and it's been running fine up until the last few months.
We've been noticing that things are not cleaning as well and it seems to be using too much water. Some days, the water level is at the rim of the doors. No float switches or emergency pump outs have been triggered, though.
According to its consumption in the Miele app and on the machine, in some cycles, its up to 26+ litres of water which seems a bit excessive. The manual states that none of the cycles uses more than 15l of water, so I'm not sure what is happening.
I've also monitored the Automatic cycle, which is supposed to be a prewash (if dirty enough), main wash, interim rinse and then a final rinse. For dishes that I wouldn't classify as dirty, it can take 4 hours to run.
It seems to go through rinses where it partially drains some water, then immediately refills and continues rinsing for hours.
I thought it might be a faulty water inlet valve letting too much water in, so I stuck a GoPro into film part of the cycle. The water is correctly shutting off, and no leaking is occurring.
I've taken all the arms out and checked they are clean and free of food debris. The filter is intact and clean. The non-return valve works fine, and the sump is clean and free of debris.
It's out of warranty, but about 6 months ago, Miele came out as the solenoid was very noisy and "vibrating", so we thought it was faulty, but they checked it over and gave it a clean bill of health. I also checked in service mode, and there are no error codes logged on it.
Has anybody had something like this before, or do you have any ideas about what might be going on? Slightly reluctant to pay Miele another £139 to come out and say nothing is wrong with it.
