Miele G5600 "Futura" Dishwasher Error Code F-24
Open the Link Below and See What Happens
This is where I land after I click on the link that was provided immediately above: "(h)ttps://ww4.miele.de/msd/MSD#/device/43049/etd/1836514681701"   It's almost entirely blank except for the banner info at top and some diagrams on the left, there's no item in the cart, the part number is one I haven't seen, it's not the Miele USA site and the 8th diagram doesn't apply to the relay.  If you don't arrive at that empty German Miele page like I did, something must be getting lost in the link translation between continents.  I don't know where the problem lies, but Miele USA seems not to want to play ball with me.
Thanks for trying, but I can't return the eBay relay if it clears the problem, so at this point I'm committed.
[this post was last edited: 12/14/2023-00:42]
https://www4.miele.de/msd/MSD#/device/43049/etd/1836514681701
£15 new for the standard relay version.
Ok, so it is a rast 5 power relay 419 11 (ea/..)
rast 5 is apparently a connector standard for cars.
Found a datasheet on RS :- https://docs.rs-online.com/854d/0900766b80ea8a3c.pdf
part no 4-1415419-0 seems to be the standard 12 volt coil version
However, the 03 at the end of the code on the case apparently indicates a custom version. So would need to check for differences, and that the keying and terminal spacing etc are the same.
I suspect there are differences, otherwise people would be selling them on ebay as miele replacement parts with a 50 quid or so mark up!
£15 + postage on Ebay, which is still overprised for a relay https://www.ebay.co.uk/itm/32560555...MIqOG9o7COgwMVxpODBx3ZvADaEAQYASABEgLUAvD_BwE
Also found the 03 part on Miele's US site https://www.mieleusa.com/e/-relay-0419-11-120103-5870220-p a snip at $83 !!!!!
The .de links give access denied from the UK.
Some of their washing machine relays look rather similar too https://www.ebay.com/itm/164414054742
Used ebay uk £13 https://www.ebay.co.uk/itm/155917064048
I also had a quick search for causes of the F24 fault, most likely is sticking relay contacts, but if that doesn't fix it, I also found a few reporting it was fixed by replacing a faulty pressure switch, which had one of the contacts not properly disconnecting when it is activated (like the video) and water ingress/ moisture on its contacts. And also a couple with moisture or bugs on the control board - one was fixed with a clean with IPA.
No worries Ralph
I got to that link from MieleUSA.com, go to support, repairs and maintenance, parts and accessories, there is a link at the bottom of the page that says view the spare parts catalog. You then enter your model and away you go. It was very difficult to use on the phone and It does work a lot better from the computer than a phone or tablet. The page that loads is in three parts, images on the left, image in the middle and parts list on the right. I’m just banging on about it, so hopefully it works for you next time, it’s not difficult to get parts.
That part number in my cart, is the same as the part number printed on the second line of text on your relay.
We can’t directly order parts in AU, we still have to call, I can’t wait for this service to land here.
Thanks guys.  I truly appreciate all of the trouble you have gone to in order to unlock the mysteries of Miele's on line presence.   I can't even imagine using a phone to navigate their site even if I landed on the right one.  I need a full screen with a real keyboard for maximum efficiency and to avoid catastrophic blood pressure spikes.
The relay is scheduled to arrive on Monday.  If it resolves the issue, great.  If it doesn't, then I'll attempt to test the pressure switch if I can find a better explanation on how to do it.  I'm not good with schematics or the lingo and electrical theory required to follow them.
If all else fails, I'll schedule a service call.  That would be far less expensive than replacing the dishwasher like-for-like.
Hopefully the new relay fixes it, but if not this video came up amongst my youtube recommendations. It's German, but subtitles are available.
He has a pressure valve with a leaking diaphragm, and the water getting in is partially shorting the normally open contacts, and causes an F24, he also mentions it leaks air when blowing in it to test it.
I noticed when I looked on that miele site yesterday the old pressure sensor has been superseded by a new part no; I'd hazard a guess that they may have changed the type of rubber used in that diaphragm to stop dishwasher detergent perishing it.
Thanks!
Fingers crossed that the relay due to arrive on Monday fixes things.
If necessary, I'll try to use my phone's Google translator while I watch portions of the pressure switch video.  I wonder if I pulled it up on the YouTube streaming channel if there would be an English subtitle option there.  I'll look into it.
I hope the relay fixes it
Hi Ralph, but that pressure switch looks like a really vulnerable design, if I had to bet, I think that’s a part that would fail fairly often after some years much more so than the relay although it won’t hurt to change the relay it does look like it has somewhere on it.
The parts issue is why we don’t fool with Miele appliances we only get a couple calls for Miele dishwashers a month, we are turning down between 10 and 20 calls a week on Bosch dishwashers we don’t fool with those as they’re just difficult to access underneath and have too many difficult problems like the plastic frame breaking for the door spring assembly.
Although the new GE and whirlpool built, dishwashers are getting more crowded underneath and they’re not a picnic to work on either in some cases.
John
Thanks John.  I agree about the pressure switch design.  I will cross that bridge if I come to it, unless it's going to be an exasperating process to access it.  At that point, I'll pay for a service call.
Oh What a Relief It Is!
The relay arrived this afternoon and the machine is back up and running.  It's been 20-30 minutes since I started a normal wash cycle with a full load, and the detergent dispenser just popped open.  I'm feeling pretty good about the machine running all the way through.  I've only pushed it back into its opening about half way and still need to pull it back out and put the bottom panel back on.  I'll do that before I run the next batch of dishes and other items that have been backing up.  I really do hate hand-washing dishes!
Thanks for all of the time, effort and advice that has been contributed by everyone.  I'm glad it turned out to be the easiest of the potentially necessary repairs.
False Alarm
The machine cut out and displayed F24 around the same point in the cycle as it did the first time.  This was sometime during the main wash because I never heard it drain again, but it's fairly quiet, I was in another room, and after taking a look inside, the tub isn't full of water.  It was definitely hot inside, so the heating system is working.
I suppose the pressure switch is the next component to check.  Maybe it will be easier to locate a new one, as I wouldn't trust a used one.
Given the machine supposedly runs the F24 check routine after drains start, it would make sense it ran a main wash.
I am still less convinced it is the pressure switch, but what do I know from here on out.
Make sure you take care to follow the instructions in the service manual for the pressure switch replacement, especially taking care about the wash pump.
Don't know how good your multimeter is, but check through the F24 chapter in the service manual aswell.
The F24 section of the manual does mention to check for resistance below a value of 10 megaohms (10MΩ) between the sensing lines on ST5 plug to the controller, although apparently the manual has got the plug number wrong according to some comments I saw, which said there was a circuit diagram printed inside somewhere. While the listed causes doesn't include a leaking pressure sensor, that would indicate it could cause that error too. I suspect a partial short to earth to one of those lines might do too.
"Cause:
Fault in the plug on the output side of the heater relay.Contamination or corrosion on the plug of the heater wiring harness can cause a bridge between contacts, which can reduce the transfer resistance below a value of 10 megaohms (10MΩ).
Remedy:1. Disconnect the machine from the power supply.2. Disconnect plug ST5 from the electronic.3. Measure the resistance between the lines of the electronic for heater pressure switch B1/13 (pins 12 and 22 on plug ST5).4. If the measured resistance value is smaller than 10 megaohms (10MΩ),then the heater partial wiring harness must be replaced"
If the replacement part was a used relay, then it is unfortunately still possible that it still is a heater relay fault, the contacts are only likely to weld when the element is powered, trigging the error after the element is turned off.
No idea if it is typical for dishwashers, but that dishwasher seems a weird design to me, after it does a drain for a while, it apparently has to turn the heater relay on and run the wash pump for a few seconds to check if all the water has drained out using the same two inputs, presumably the element doesn't come on because as long as some water has drained out only one of the two switches in the pressure sensor would turn on.
Those routines don't check for proper draining.
EU DWs have A LOT of redundancy and a lot of self check routines.
Ever since there have been a few cases of fires in DWs due to bad safety design, and with European design standards being VERY strict for appliances, having such self checks is just cheap insurance.
After each drain step it does check the water level via the pressure switch and the recirculation pump.
Only if that test confirms a drain, it continues the self check routine.
The pressure switch function is validated once at the start of the cycle.
All tests afterwards rely on that confirmation to be correct.
That test in it self relies on the assumption any significant water level in the machine before start is noticed by the user.
The test for the relay then relies on a working pressure switch and no creeping current.
Given that a value over 10 mega ohm is required, the electronic appears to be REALLY sensitive on those sensing inputs.
All of that is just to make sure the heater NEVER runs without water.
Even if that means some machines to be scrapped earlier than possible, it's better than thr reputation loss of a house fire.
BSH DWs don't use any real pressure sensors and only rely on drain pump and wash pump feedback for water presence sensing and thus safe heater operation.
That's why the wash pump errors on those happen WAY before the pump is actually unusably worn out.
Keeping big safety margins there means that any wash pump that could remotely sense water presence wrongly would throw error codes WAY before.
Difference is: On the Miele, it could be several components that could cause that issue.
On a Bosch, it's only one part. That part is designed to be as low cost as possible.
That huge safety thing in EU DWs is also why basically ALL DWs have float switches and a closed bottom pan.
Given we have HUGE amounts of dense flats in buildings, and DWs are always in kitchens, and YOU pay for ALL the damage a broken appliance could to ALL flats in a building, it's just way cheaper on the whole to make DWs uber safe against leaking and fire.
Ixnay on the Itchsway
Yeah, all of that electro-jargon is over my head, and the mention of wrong info in the manual was enough to make me decide to cut the crap and make a service call.  The relay was as far down the rabbit hole as I felt comfortable going.
I'll circle back to this thread to share the findings and results from the technician visit.
Have a look at where the cable joins the main PCB
A long time ago I had a Miele dishwasher that was corroded where the pressure switch joined the main PCB.
It has 4 wires, 2 go to the pressure switch and 2 go to the heater relay.
Richard
Dishwasher heating elements
This is one of the reasons why domestic dishwasher still put the heating element in the bottom of the tub, it’s a lot safer to have the heating element in an exposed application, where it will not start a fire rather than putting it inside a plastic pump housing.
hi Ralph, have you looked into changing this pressure sensor it might be quite easy, although it is pretty tight under there you may have to pull the dishwasher out to access it. I’ve changed a couple of main pump motors in Miele DWs and it’s not too awful other than having to pull the machine from it’s installed position.
John
Hey John,
Yes, the machine has been extracted since I started investigating the problem.  It has to be placed on its side in order to access the relay.  I only pushed it partially back into place to do a test run after replacing the relay.
I called an authorized Miele repair service today -- no thanks at all to Miele's poorly designed customer service web site.  They are bent on making it next to impossible to find any sort of assistance with problems, sending the user in circles or to dead ends, and I am done with them in that regard.  I used Google to locate an authorized Miele repair service, found one with good reviews, and they seem to focus on dishwashers.  I have an appointment for a week from today.
Since I've already paid for an overpriced relay that didn't resolve the trouble, I think it makes sense to stop throwing money at this issue when there's no telling whether another overpriced component will rectify the problem.  I'll leave it to the experts, and John, I know I'm preaching to the choir with that decision!
Assuming the machine can be successfully repaired, I'll use it until something else goes wrong.  As much as I love this dishwasher, I won't pursue repairs again.  I'll find myself a nice Whirlpool/KA that offers straight-forward support, repair service and access to parts.  Miele has soured me on ever buying another foreign brand major appliance.
