Not even 550€ for NIB machine like that - who could leave that offer sitting around if you were needing a DW anyways since you were moving?
So, I had to move (long story) (coming soon to a forum near you) and needed a DW.
Was thinking freestanding as that would have been cheaper on the kitchen furniture side of things.
Was looking at Bauknecht for about 500€.
And then this happend:
We had an offer at work that was half off of the MSRP for certain integrated appliances.
And somebody at headquarters must have gotten wrong directions - or they wanted to rid old high price stock.
So, they half priced this Miele DW. Plus my employee discount, I got it for under 550€.
Since I am currently living alone and only moved in like not even 2 weeks ago, I didn't do much with it yet.
Loading is interesting, still getting used to the upper rack. Spacing the lower rack with pots and stuff is still a learing curve.
But plates take up nearly no space in there.
So it does have capacity.
AutoOpen is working like charme.
I am currently using Finish liquid I got for cheap in bulk.
Horrible detergent.
So I activated the Extra Clean and Extra Dry options.
They moved the filter to the center around the spray arm, stream lined the run off surfaces, cut away the metal top spray arms, removed EVERY downward facing hole on the middle spray arm, moved the water feed tubes for the spray arms to the inside of the tank, split them up (they are 2 seperate spray zones from what I can tell now, but I might be wrong).
And they added their EcoPower technology.
So what exactly is EcoPower technology?
It's Electroluxes impuls washing technology!
Yeah, they just copied that.
On the Eco cycle I noticed it during the main wash after the heating. Low washing with high pulses and some cavitation towards the end of those high pressure pulses.
They however extended that to pulsed intermediate rinsing. I do assume they use these on Eco as well, though I haven't confirmed that yet.
But on low load low soil Auto cycles, the DW does do a complete drain - fill - drain for the interim rinse, however the interim rinse is 3 second ish pulses with 10 second or so pauses in between for like 5-10 min.
Pump does cavitate towards the end of the pulses.
Maybe the pulses are pump sensed (cavitation -> lower rpm).
As I said, ran maybe 5 loads so far.
More as I learn!
Horrible detergent.
More as I learn!
