Does use cooler air
After experiencing two 9xxx dryers when Miele discontinued this dryer and the 4XXX series washer it didn't take me more than a minute to know the reason. This dryer is smoother and more polished acting than the first Miele dryer, but the program problems remain. The dryer does use cooler air than the Whirlpool it replaced. Either that or there is so much air flowing in and out of it and it just feels cool. I never really tested the temp, but I remember reading the BTUs of the gas burner and they were lower than the Whirlpool.
I have my outside vent extended away from the house by 4 feet because I don't want any lint to get inside my central ac unit which is near the vent. The vent pipe was just sitting there, but when I got this dryer and used it the pipe was bobbing up and down and flopping all over the place so there is def. more air moving within and out of the dryer.
The burner on this dryer never cycles off. It runs all the time, until its time to reverse tumble, then it will shut off, do the reverse tumble then resume a few seconds after the forward tumble starts.
It has a turbo setting. Can't tell any difference in the heat...it just doesn't do any reverse tumbling. There is the thing about the room temp because I think I read that the design specs are for a room temp of 68F. My laundry area may be slightly over this in the summer, but it is way under in the fall and winter so maybe that is a factor too.
My gas usage did not increase after purchasing the dryer so I guess it just has to run longer with a smaller burner.
If I use Extra dry for all cottons everything is OK and nothing feels over baked, its just frustrating that Normal and some of the other settings don't work well and are not worth the money this dryer cost me(although I did get this one for free after the Miele first try mess I got at first). I can't say the same thing about my 1986 washer so this dryer was just not the best from Miele.
Going forward washers from Miele(little giant in mind), gas dryers from USA. My old Whirlpool wasn't fancy but it worked.
