I find a small chair on wheels by the Miele aids immeasurably in helping to load and unload the washer. I use a small (clean) hamper to transfer the damp laundry from the Miele(s) in the workshop to the Neptune dryer in the main house.
However I don't think it's a simple matter of being equivalent to loading and unloading a dryer.
For these reasons:
1) With a traditional top loader, one can simply invert the laundry hamper over the washer tub, letting the clothes fall in by gravity. This has the added benefit of allowing one to minimize contact with dirty laundry.
2) When transferring the laundry from the traditional top loader to a front loading dryer, again, gravity makes the chore easier. Once the clean, damp laundry is pulled from the top loader, it can simply be tossed from that height into the dryer.
3) With a front loading washer, one must extract the laundry from the horizontal tub. More often than not, the laundry will fall to the floor during the transfer from the washer to the dryer. If the floor is squeaky clean, no problem.
4) The front loader washer to dryer transition can be eased not only by using a small chair, but also by using a small hamper to catch the laundry as it falls out of the washer, and then hoisting the hamper to let gravity assist its transfer to the dryer, without anything hitting the floor.
5) Most front loader washers do tend to spin faster than a traditional top loader. This means that the wash may be more difficult to extract from the front loader washer than it is from a top loader. More modern top loaders spin faster so this may no longer be a big difference. And Miele has a post-spin tumble feature that helps to dislodge laundry that otherwise would be plastered to the drum.
