cantare
Just got a used USA model W1213 as a replacement for my failing 1918. It came with no power cable. I didn't expect this to be an issue since I have the cord from my 1918...a four-wire AWG10 NEMA 14-30. All four connectors were used on the old machine.
The newer machine has a main terminal block with only two spade lug connectors (L1 & L2) plus separate chassis ground. Yet the user manual for the W1213 refers to the same 4-wire 14-30 plug.
Does the 1213 simply use the two "hots" (ie, red/black, 240V difference) internally, and leave out the neutral (white)? Does polarity of red v black matter in this configuration?
