I recently purchased a used Miele washer dryer. The previous owner said it ran great for her. She needed a larger machine and did not use this machine for a few months then decided to sell it. I hooked it up,turned it on, it filled with water but would not agitate,tried just the spin cycle,would not spin, I drained out the water, drain pump is fine. The drum will not budge when on or off, mechanically or manually. I took off the top and did not see anything unusual, took off the belt, tried the motor, motor is fine.Checked the pin trap, looked OK. Took off the rubber boot on the front, didn't see anything binding the drum. The previous owner said she never heard  grinding noises or anything when she used it,said it was a great machine. She has agreed to refund my money. However, I'm curious about a few things? Could a machine bind up like this with no signs previously from just sitting for a few months?  When bearings need replacing, is the drum still partially movable? I would love to get this thing going, does anyone have any ideas or does it sound like bearings ?
