I had/have a problem with the cold water input valve, so in order to better diagnose the problem, I tried to put it into service mode as per the W1900 technical manual. Tried a dozen times, but could never get the acknowledgement indicator (successful access into the Service Mode is indicated by a flashing “Pre-Wash” LED).
Anyway, it appears that I must have done something successful because it is now stuck in a mode that is not matching the service mode description. These are the symptoms:
1. Electric door will not activate.
2. On/off button will not flash the delay start led.
3. While on button locked down, the pre-wash button will cause the drum to rotate (slow rpm).
4. Moving the selector from start to any selection, nothing will happen. But return to start and then a four blink countdown starts proceeding to each entry of the program sequence starting with main wash then downward.
5. Moving the selector to a wash cycle while the four blink countdown is occurring will cause the blinking cycle to start.
6. The time display is always off.
7. Turning on/off will not reset the mode.
8. Unplugging for 4 days will not reset the mode.
I'm able to do a full wash by using the manual door release and selecting a wash cycle within the four blinks of the main wash led, but obviously this is not a convenient solution.
Any suggestions? Was able to temporarily solve my water inlet problem by swapping the rubber diaphragm between the main and pre-wash solenoids. Discovered a broken shock during all of this and hopefully, this should resolve a mysterious clunking noise; and finally fixed a deformed selector knob that has been annoying me for years. She's all ready to rock and roll if I can just resolve this goofy mode I'm stuck in.
