Miele W9245 dead
freshlinen
Active member
Nov 29, 2010
42
south africa
Fixing a miele W9245 Washing machine.Switched unit on and systematically indicator lamps light up giving short flashes then on light remains but no waterintake or pump sounds.Tried all cycles same happens.Any advice?
Some advice
First of all, before I mention anything, do you know how to work on these machines? If not, it would be advised that you contact your authorized Miele service center ASAP and have a qualified technician do the work.
If you want some forum member to help you with your problem, the first step is to be a bit more descriptive about the problem you are having. How are the lights flashing? How quickly? For how long? Are there any pauses? Which lights are flashing? In what order?
Can you take a youtube video of the issue you are having and post it here?
Gee thanks,qaulin?The washer dial is switched at any cycle then the ON lamp flickers 1blink1blink mainwash and the next lights will be rinses 1,2 and 3 then spin but all in 2-3 secs of 1Blink1blink until the only the ON lamp remains again.No waterintake,no pumpstartup and no washmotor action.I have Miele agent booked already.What do you think my friend?
Can't help you out there. I'm not a Miele service technician. I don't have any Miele service manuals either so I can't help you.
If I were to speculate, I'd probably send you up the wrong path as I'm not skilled enough to work on these machines.
What I would be interested in, is knowing what the technician found.
Miele W820 got fixed by repairguy today.Bad pump taken out and fitted with pump from W9245/925.So leak gone.Even after test wash.However W9245 electronic board must be replaced and obviously a new pump as well.Both main motors of each machine still good.Miele quality even in used machines impressive.Keep you posted when the W9245 is fixed qualin.Thanks guys.
