Mint doesn't even describe this new find!
jetaction
Feb 12, 2005
610
Minneapolis
This made its way home today and I couldn't resist. The only thing is the rubber fitting over the nipple for the power shower wash arm was so brittle I broke it off. I will have to find a replacement, any suggestions? I would be interested in a copy of the owners manual as I enjoy reading these.Also, the model # is 1SP40T1 and the serial number is RT7-05311. If I dated this correctly it is August of 1960, experts can weigh in! Very quiet machine in my test, I was surprised at that and it was empty when I tested her.
A question....
If you look at the 2nd picture of the racks, what are the ones higher up with the two prongs together in sets? They are on both sides of the interior. Haven't seen these, too high for saucers.
Great looking Mobile Maid
Check out the auto ephemera section to see if there's any paperwork there you could use for your machine. They do have several models listed. Perhaps they could give you some guidance.
As far as those double tines I would think it would be for loaded a double row of glassware, mugs, and cups. some of which would hang over the midsection of the open area.
Congratulations on getting a great looking machine!
Congratulations!!
That's a very nice looking machine. Can you tell me what the stainless part is attached to the bottom of the tub, just above the impeller? Is it a baffle?
I may have a complete water feed for the Power Shower that you could have. Let me check.
Have fun with it!!
Don, those rows of pins on either side are indeed "cup shelfs" for coffee cups--so popular back then.  One of the PODs featuring this dishwasher, it shows these being used.  Just don't know which POD.
Congratulations!
The machine is short because it is basically the interior tub of the built-in machine without the frame around it, just a hinged top added. One advantage of this was that it could be "garaged" under a countertop if the housewife did not want the dishwasher visible when not in operation. That was not a convenient way to have it for adding things during the day unless you accumulated dirty dishes in the sink before loading the machine.
The baffle at the 12 o'clock position in the sump was an important addition to this machine. When the machine drains, the motor spins in reverse. The baffle was placed there to direct the water and food particles down into the drain and to keep it from being swirled up the sloping walls of the sump as the impeller turned in reverse direction. This was a big advance over the previous GE dishwashers where the timer ran off the main motor so the main motor could not stop during the drains. The water and any food soil could not settle out near the drain because the impeller kept spinning. At the end of each drain except for the drain from the final rinse, a sub interval timer opened the fill valve for maybe 3 seconds to flush clean water through the machine. GE did that with their combos also to remove as much soiled water as possible from the sump after each drain since the combos did not spin until after the final rinse.
I think the secret to this machine's superior washing action was not only the shape of the impeller, but the fact that it was metal so it did not develop dull leading edges and, in being hard enough not to develop the dull leading edges, it was hard enough to grind up food soil it hit in the water.
The patterned top is GE Textolite, not Formica, but a similar product.
We sure enjoyed ours. I hope that you have fun with yours.
Don this an amazing find!  I have only seen one other GE impeller dishwasher with the extra cup racks and I believe it also had been a 1960 model.    I think you found a low-use machine here!!
The hoses of the GE Mobile Maids are something of a weak point so check them out carefully.  I still have to try this out, but I managed to unscrew the water supply hose from the Unicouple assembly of one of mine and got someone who works with hydraulic hoses to attach a new high-pressure hose to the original threaded connector.   I haven't tried it out yet, alas so I am not sure that will be a good solution or not.
In a pinch, you could substitute a more recent hose assembly but you probably wouldn't be able to save the original Unicouple...
Can I guess the cycles base on the four buttons??   Fine China and Crystal, Utensils, Normal Soil, Heavy Soil (with water heated IIRC) Wash are what I'd think of first.
I know some in CT who will be chiming in about this one!!
[this post was last edited: 1/23/2015-07:18]
Wahhhhhhh !!!
I want one of those sooooo bad.
Congrats. We had the Princess Pull out when I was a kid. These clean great and with the sound of a Mack Truck roaring though the kitchen.
I have some parts somewhere for this and some other models if you should need something.
Good Luck with this Beautiful Machine.
Thanks for the input, I wondered what that baffle was for Tom, now I know.
Paul the buttons read:
Open Cover
Daily Dishes Mixed Loads
Utensils Pots Pans
Fine china & Crystal
I will have to be careful with the hoses as they seem a little hard, I do have an extra set that I could part out but of course I would want the shiny stainless uncoupler on them....
This model has the feature that the top pops open in the dry cycle, kind of fun. As far as the top sets of tines, cups don't stay up there and even my smallest juice glass would prevent the top from closing. Maybe it's just my cups and glasses....
There are three cycles and Cover Open so it was China and Crystal, Daily Loads and Pots and Pans. China & Crystal did not heat the water and skipped one pre rinse, as I remember. The Pots and Pans cycle also skipped an initial rinse and shortened the dry to 5 minutes in ours. All cycles except China & Crystal operated the water heater during the wash and rinse portions of the cycle. If you wanted something grungy cleaned, it was best to use the regular cycle and check when the lid popped up to see if it needed any further cleaning.
I used to take out the top rack and put the round charcoal grill in for a good cleaning.
And fully featured she is!
I noticed that the water was being heated, this really was (from my small pool of impeller knowledge) about the most fully featured, best performing of the impeller machines I believe. I am really impressed so far and I have always kind of written them off. Tom you are correct about the cycles skipping the first rinse for china and pots/pans. Seems that pots/pans would have the longest cycle. It appears the lid opens soon into the drying cycle, is this correct?
Three cycle buttons
Don, thanks for the info - of course this would have to have a 'cover open' button... LOL  Pretty darn difficult to load if not, eh?    I guess it was only the SU70 Undercounter that had the 4 cycles.
I was thinking about the connection sleeve for the power shower; maybe the flexible part of a faucet adapter meant to go on a tap where one could not disconnect the aerator would work.  They should be in the plumbing department of the larger hardware stores and they usually have a standard 3/4 inch garden hose connection on one end.
It's maybe 4 minutes into the dry cycle when the lid opens. If you look down into the opening for the Unicouple you will see the opening into the front of the tub where the cool air enters to set up the convection draft for the drying. They gave it a few minutes to build up heat before the lid pops. It was neat to lift the lid slightly and look down into it in a dark kitchen and see the Calrod glowing red. Another neat thing is to take a powerful flashlight and shine it into the Unicouple opening and on down into the tub (where the water fills at the front) during the washing and rinsing. It's easier to do now with LED lights. If you angle the light just right into the tub opening down there, you can see the water moving around at the edge of the sump area. My parents finally got tired of asking what I was doing when I was looking at various things while the machines was running.
If I were designing it, I would have put a light in the dial.
I wonder if somehow baby bottle nipples could be used to fashion the seal for the Power Shower feed.
I wonder if the Pan cycle was shorter because they used to recommend that you wash the pots while you ate the meal. With the noise that thing made, you would have to have one of those colonial houses with the kitchen in another building to be able to talk while it was running.
It used to be fun when we would have people over and as the table was cleared, the women would want to help mom do the dishes. She would take them out to the kitchen and tell them that there was nothing to do and show them the dishwasher. They would be amazed the first time they saw it. We did not have a disposer at the old house so she would show them how she removed any excess food into the kitchen waste container and would load a few plates, maybe. She would then brew the coffee and get the dessert ready and then get them back into the dining room for dessert and coffee. We had this beautiful Inland Glass carafe that had a round bottom and a long neck that was silver on glass. That had to be heated with hot tap water before the coffee was poured into it. That was another of the entertaining rituals. The letdown came with the extinguishing of the candles after the guests left and, to this day, the aroma of coffee and candle smoke evoke sad post-party feelings.
