MODERN MAID IMPELLER ROTO RACK DISHWASHER PICS
soberleaf
Dec 28, 2008
1,195
started to give the modern maid impeller roto rack dishwasher a tune up today. got this from the church when i visited matt (everythingold) several weeks ago. this is my first impeller machine and i was anxious to see how it was built.
all in all it's in great shape.
racks are perfect! bottom rack!
impeller does have several peices missing
so if anyone has any info on where i could buy an impeller please let me know. i would greatly appreciate it
one more
here
i watched this machine in action the day i took it out of the church and even with the broken impeller peices it really moves the water!
i don't plan on ever using this machine to wash dishes as i'm afraid to break impeller more than it is. this one will be a conversation peice only. but i am going to test it this week when i get it back together.
it has no water seal
but uses that extended tube that the impeller slips over. there is a rubber boot at the top that the motor shaft slides thru to help keep any water out of motor shaft/tube area.
there is another larger diam rubber ring near the bottom of the tube that acts as a water baffle also.
rubber seal
is still very soft and pliable for it's age.
the other rubber ring at the bottom of the tube is also
here's the front
all stripped down. note the unusually large detergent cup
it is operated mechanically from the timer by a cam
i will show pics of this when i put timer back on.
the fill "funnel"
is fed by a copper tube! those days are over!
note the drain pump and the large rubber tube that connects from the tub to the pump. this was very dirty and brown in color and i soaked it ans scrubbed on it till it looked much better!
here it is
all clean again. well as clean as it will get
that small hose coming out of it's side connects to a water pressure switch.
on the top of the machine is
a large rubber vent like device. it was equally dirty but cleaned up well
here's the underneath showing
motor, fill solonoid, water pressure switch and drain pump.
this is the only dishwasher i have ever run across that has a full size metal plate or pan that sits under the motor and connects to all 4 of the legs.
normally i would take it off but the drain pump mounts to it and i don't want to disturb it's originality. i mean it was designed with it so i have to keep it. i did take it off today to get motor out however.
motor is
in great shape, runs very quiet. it's a 1/3 h.p. 1725 rpm.
gave it a good oiling at both ends (we like that).
let it run awhile and it stayed nice and cool.
here's the motor mount
note the drain tube that the rubber connector clamps to. it had a bit of rust on the end so i got out my wire brush and drill, some sand paper and my rustoleum primer.
this is the only rust on the entire nmachine!
