the motor and heater element
are wired in parallel and both operate together thru both the wash and dry cycle
this machine has a rinse, wash, rinse, wash, rinse, rinse and the washes are 8 minutes each, all rinses are 3 minutes except the final which is 5.
it says each fill is 6-8 quarts, timer advances 7.2 degrees every 60 seconds and drain pump runs when motor is off
there is a rinse/hold, wash/hold, regular wash and a super wash with hygenic rinse cycles.
dry is 17 minutes and total cycle time is 49 minutes.
gee, these new machines today should take note of this little
iumpeller model's ability to wash and dry a load in 49 minutes! and it probably does as good a job too! with a single impeller!
hope you dishwasher fans have enjoyed this little photo post, i am going to take a break and take a couple more pics as i start putting it back together here. will post them later here tonite.
