Mom's Washer
suedenim
Active member
Jul 31, 2021
38
Lincoln, Nebraska
Not quite sure how old this washer is, but it needs repair. It makes a very loud banging-whirring noise in the spin cycle. I was wondering if someone could assist in what she has.
It is a 1997 model. The belt is probably the banging noise and if the whirring noise your referring to is like a loud roar then the upper bearing is bad more than likely due to a bad tub seal. If the whirring noise is more high pitched it could be the wash basket if it doesn’t have a load in it which is normal.
was told to replace it
The repairman talked with Mom over the phone and told her based on what she was describing, it should be replaced. I don't know what she wants, but I'm going to suggest the Maytag commercial as a Speed Queen will outlive her. She does have the option to get a front load but never has used one before.
