More HAIER fun
johnb300m
Aug 31, 2015
1,277
Chicago
I was real bored tonight, so i designed the wash/spray diagrams in SolidWorks of the POS Haier dishwasher I have.
It's aproximate, but still pretty interesting and cool looking.
view2
view2
the PowerTower pattern was HARD to do. But still looks good.
GE's PowerTower pattern is fantastic; full coverage.
it washes "OK". It has the powerful GE pumps, so it has all the power it needs. The top rack gets plenty of water except in the corners sometimes. This machine has no filtration whatsoever. So sometimes there's crud left over, but everything does come out clean as long as you choose a long enough cycle.
I'm not a fan of all the jets facing inward though.
HAIER
This is a interesting dishwasher. I have not seen it on their website. You did such a nice job with the pictures. Is the detergent dispenser like the GE? Is their a water heating option?
Peter
details
yeah it pretty much sounds like a GE. You have the definite drumming of the tub by the torential spray tower. The motor is very quiet, you don't even really hear it. the water noise drowns that all out. there is no drain solenoid "clunk" because this machine has GE's separate drain pump.
it actually is on their website [which is not too flattering]. my machine's model # is: HDB24EA
The inner door and most of the inner tub is a Whirlpool copy. the detergent cup/rinse aid unit is on the left side, and it is a UNIQUE design.
the upper rack is a crappy whirlpool copy, and the lower rack is a crappy GE copy.
There are no options other than hot/cool dry.
However, the noticeably low wattage heating element seems to run most of the wash cycle.
It has 5 cycles:
PREWASH: WASH-RINSE-RINSE-RINSE-WASH-RINSE-RINSE-DRY
POTS/PANS: WASH-RINSE-RINSE-WASH-RINSE-RINSE-DRY
HEAVY: WASH-RINSE-WASH-RINSE-RINSE-DRY
NORMAL: WASH-RINSE-RINSE-DRY
RINSE ONLY: RINSE [DRY, if you leave the hot dry on]
Since this machine has NO filtration, the Normal wash is pretty useless due to not enough water changes.
