stevet
I did not want to hijack the thread on the stacked Duets from Germany so I thought I would add my tale of woe to the forum.
We have a WFW9150 series Duet which is just over 6 years old and it has given us good service for all intents and purposes but now it is failing to complete cycles on a random basis and returns an error code(just yesterday) of 9-1. Since there is no display we have to decipher it according to the tech sheet which for some unknown reason, I have either lost or misplaced. I have a set that another member sent me which is basically close but I would like to be sure.
In the past, it gave an 8-1 code which is a long drain period and it has often left the water in the tub and clothes soaking wet.
Yesterday it did it again and the drain pump was very hot. I pulled the plug to clear the code and by then I assume it cooled down enough and started draining again.
I might add that the pump is making more noise and groans as it drains than it ever did so I am thinking the coupling or impeller shaft is not running true anymore, though an inspection of the pump did not reveal any abnormal wear or binding.
Did a small load wash to rinse them and it was fine and then another wash with shirts on delicate and it was fine. My wife now uses "SILK" exclusively because that seems to be the only cycle it works thru fine. The others will also randomly error out as well but not "SILK".
Does anyone have the tech sheets or error codes for this model? And is the drain pump at its life's end?
Any help will be appreciated.
Thanks
Steve
Thanks
Steve
