More on Disposals (for disposal lovers only)
bwoods
Jan 28, 2005
947
Interesting to hear about people's experience with disposals. I, like Tolivac, had a love of them and purchsing and testing different models is sort of a hobby (albeit, an expensive one).
It is correct that only three U.S. manufactures now exist, (1) Anaheim-- (Sinkmaster, GE, Waste King, Whirlaway, etc) with various models operating between 2700 and 1900 rpm, and all have a permanent magnet motor. (2) Emerson Electric, who bought In-Sink-Erator--(ISE, Whirlpool, KitchenAid, Maytag, ACE, Sears Kenmore, etc) and (3) Viking Range Corp. (who bought the design rights from Whirlpool when Whirlpool bought the KitchenAid division from Hobart.
In the previous threads many belittle GE. Most of these individuals probably don't have a true GE but one of the Anaheim clones. The main characteristics of these is they stink (plastic parts in the grind chamber scratch and absorb bacteria), and as someone mentioned, materials collect under the lower rim below the splash guard and the underside of the splashquard itself. They are also characterized (the 1hp and 3/4 models) by getting little pieces of corn cob and similar hard wastes trapped under the swivel impeller. This throws the grinding whhel out of balance and causes vibration. Even under normal circumstances they are noisy grinders.
GE quit making the Disposall themself in the late seventies (if I remember correctly, about 1979). They had two primarily designs. One set of models used induction motors and operated at 1725 rpm, like most disposalls. They were larger with a heavy cast turntable (aka flywheel or grind wheel) They were quiet, reliable and had few faults.
GE's other design had models using a series wound motor operating at 8000 rpm. This design was quit innovation. Series motors are lighter in weight and much smaller for a given rpm range. You either have to love their series models or hate them.
GE series models (later called the Piranha) sound almost exactly like a vacuum cleaner motor when they wind up with no load (no garbage, no water). A series motor has extremely high start-up torque (no ned for a starting capacitor). It's torque actually increases under load by pulling more amps, as speed drops, torque and amp draw increase. It will fight a load until the bitter end. That's why series motors are used on most drills and blenders.
As far as the love it or hate it aspect. People hate them because they are noisy and can occasionally fling a piece of bone and water particles out of the sink with great velocity if you don't use the cover.
People who love them do so because they are lightweight and easy to install. Incredible torque for the size-- do chicken bones almost instantly, pork chop bones in 10 - 20 seconds. Corn cobs grind very quickly but don't feed them in non stop because the little motor works so hard that it overheats quickly and kicks out the thermal overload
Both the induction model and the series models are entirely polished stainless steel..the hopper, cutters, flywheel and swivel impellers.They rarely develop a smell and the interiors almostlook nice and shiny.
In the mid 80's, GE lent their series motor design to Anaheim to use on their GE labeled disposal. GE's advertising logo was "They're Back!". but they weren't really. I bought several of them and they just were not up to the original GE standards. Anaheim went back to their generic base models after a few years. AS they go down the assembly line, they slap on GE labeled housing, a Sinkmaster housing, or a Waste King housing depending on the need. All absolutely identitical. All are readily recognized by their small diameter throat. Hard to cram large watermelon rinds and grapefruits down. A few like Sinkmaster Elite used a three point professional mount instead of the plastic ring, and these have a little larger diameter throat.
Of all the disposals my favorites have been;
True GE built Series motor models-if you don't mind the noise and the ocasional high speed projectile, there is nothing faster. If your drains are prone to glogging these are good as the water is pushed out of the machine with so much force it helps to keep the drain lines clear. Fastest machine I ever had on pork chop bones (unbelievable, really) and peach pits.
Maytag-Built models (made through the mid 80's I believe). A good all around machine. Very quiet, dependable. Does everything well, although nothing overly great. Fine grind with the undercutting tooth, so unlkely to stop up drains when grinding corn husks. No faults, really. A very, large and heavy machine, so you need plenty of room under the sink. Wide opening in the throat.
Pre-Anaheim, Waste King (up to early 90's) Their 3/4 hp unit, is like the Maytag, in that it was a good all around unit. One of the finest grinds, especially on bones. Quality control was not always the best in later years, however.
ISE-only tried two of these but had three Kenmores, which are virtually the same, one was lower line 1/2hp, good except suffered the Anaheim problem of getting out of balance, on bones, but not corn cobs. Little pieces of bone fragments got under the swivel impeller and kept help it open. Recently I had the 1hp model(I think it was the 777 SS) was a good machine. Very quiet. Not as fast as the Maytag and definately slower than the seies wound GE. It uses a 360 degree rotating impeller. This is very good for jam reduction. But reduces the force on the food against the shredder ring as they are oftentimes swung away. Fairly slow on peach pits. Very respectable on corn cobs, great on watermelon rinds and satisfactory on pork chop bones. Beef bones take too long, so forget those. (Heavy beef bones are too hard on any machine, in my opinion, except for the Viking). Although In-Sink-Erator (Emerson) claims they use an endurance test using steer bones in their disposals.
Viking (Formerly Hobart's KitchenAid)-never had one of these, but when I save up $420, I plan on it. The advantage, it is the only brand still made with fixed impellers. The impellers cannot move away from wastes but relentlessy keep driving them agains the shredding ring. Very fast from what I hear, however prone to jams during bone grinding. that's why the "Wham-Jam" breaker feature. Except for a more powerful motor, these are the exact same units KitchenAid put out in the 80's.
If you look on ebay you will see an original KitchenAid that looks like someone put it out of the city dump, They are asking a "Buy It Now" price of $54.00. They have relisted it three times with no takers. (for obvious reasons) They are highly collectable, but not when they are a beat up piece of junk with half of the parts missing and looking like it had been dragged through a gravel street for two or three miles.
Keep your eye on Ebay if you want a vintage disposal. I have bought two of the GE series units there, one GE induction batch feed and one of the original Maytag built models. Had a really bidding war on it, but got it for round $180. I even saw a vintage Westinghouse, once.
Barry
disposers
Like Bwoods I collected new disposers for awhile-when they were not real expensive.The GE hi-speed machines use a universal Series wound motor-just like in a blender.I have used many of those-one was installed in my mothers Levitt home.Must of been a special model.Didn't have an outer sound jacket-but did have the GE Carboloy cutter-that unit would shred almost anything you put in it.The cutter was tungsten carbide.-and it was sharp. Was actually a carbide metal cutter lathe bit put in the disposal.Fixed impellors are not necessarly better than swivel ones-Swivel ones can be HEAVY(like the blades on a tractor drawn bush hog mower)so they won't swivel back unless the item is hard.And they give a real hammer like blow-the fixed ones just rub the items over the stationary shredder(grind ring)I did have one of the older KA machines that did jam so badly I took it apart to free it.Thats a disadvantage of those.If it jams you can be in trouble.This one didn't have the "Wham-Jam" breaker feature.Got it from Wards on sale.They were dropping the KA line of appliances.Actually the orig KA machines were VERY SLOW-but more thorough than others.Their discharge was finer than other machines.I would like to get one for my septic tank equipped home.They are good for that.I don't really like the ISE machines because they don't shred waste very fine-they can plug your plumbing.Their discharge is VERY coarse and they will not cut up stringy waste.Also the newer models don't have the cast shred rings.The cast rings are best-more durable-self sharpening if the machine has a reversible motor.The stamped rings wear more quickly and dull quickly.The Viking-vintage KA machines have the cast shredders. Same with the Maytags.I have tried to deal with used machines-but cleaning them up is just a messy-smelly job.also the shredders may be to worn to use it.
Austin-looked at the Hobart machine in your link-that is a commercial model-You could use it at home if it would fit your drain opening in your sink-and the motor could be run from 120V.That would be a SUPURB unit.-the BEST!!Cast metal rotating shredder and Cast stationary shredder.Would be better than ANY machine normally sold for home use.I did find a GE disposer in the dump site where a radio sation I was building-the machine was mashed and crushed by the Heyster "Pactor" dozer compactor-couldn't be salvaged or run.Was a nice machine though and very vintage.
Thanks guys for your expertise.
My GE, that came with the house, in 1989 is now leaking, or it was for some time before I noticed it. I had to take the "composite wood" bottom completely out of my sink cabinet It was a sponge. I bought the ISE badger 5,$89.@HDepot It was $70.for installation the guy is coming Friday. I really only "dispose" the crud from washing pots and pans. (Our trash pick up is twice a week) so bones and cobbs and all that I just put in the trash. Anyway I will be glad to get it put in, the dw drains into it, and I do MIND not being able to use the DISHWASHER. I had forgotten what it was like to wash dishes by hand every day. Bwoods you are right, I just looked and it is an emerson product. I will let you know how this weeks project turns out. Oh yeah the Badger5 is a 5/8. With my description of my disposal use is this going to be o.k.? Thanks alr2903
For disposers that don't get any bones-would suggest running several ice cubes thru it once a month or so to break up the "sludge" that builds up in machines that gets a "soft" food "diet".The sludge will cause odors and corrosion-esp in Badger machines.shredding the ice cubes with PLENTY of water will scrape away the food sludge.also it will help keep the stationary shredder cutters sharp.Does your Badger come with a removable Splash guard? The underside of fixed splash guards can get covered with sludge as well-you will need to wipe it off now and then or else it will smell and cause the rubber to rot away.The removable ones can be taken out and washed.In one apartment I moved into that was the problem-the splash guard was so rotted the peices fell out and I replaced it with a removable one.- Hardware store replacement for ISE.
Badger disposals
are lousy. Spend a little more and get something decent higher up in the line.
I don't like it when dishwashers drain into the garbage disposal, it obviously means that if something happens to the garbage disposal, it puts teh dishwasher out of commission, too. There is a drain tailpiece available that lets dishwashers drain directly into the drain, bypassing the disposer, I made sure I used one of these in both houses I've lived in, and recommend it to everyone when the subject of dishwashers comes up.
My new Disposer
I just purchased last Friday night at Home Depot an ISE 777ss. I put it in that night. As you may know this replaced a GE Diposall from 5 years ago. The difference between these two diposer is like night and day. I am far happier with the ISE. It is extremely quiet and does make short work of hard items like olives pits and bones. I just love it. I cleaned out my fridge last night and did not get splashed with "food boggers" once. :-) .
Chris
Chris's new disposer
The GE you replaced was really an Annaheim Manufacturing disposal. GE just sticks their name on it, like they do many things, now. I would take an ISE anyday over an Annaheim (aka..Sinkmaster, GE, Waste King, Whirlaway, Frigidaire, etc.) unit.
Disposals which were actually manufactured by GE (prior to about 1980)were truly quality and innovative machines.
Barry
BTW, in addition to ice, I sometimes wad up a paper towel soaked in dawn or other dishwashing liquid, stick it in the disposal and turn on the hot water. As the disposal turns the paper towel to pulp, it swirls around the chamber along with the dawn detergent, removing the greasy crude. The detergent froths up through the splash guard and helps to clean the underside of it too, especially helpful if you don't have a removable guard. If your disposal still has the stinks, do it again, but put a little household bleach in with the detergent and papaer towel. This will kill the bacteria in the machine and take away all odors.
My GE (real GE) has a removable splash guard. I take it out every so often and put it, and the stainless steel stopper, in the dishwasher. They both come out really clean.
Foaming Disposer Tablets
I've seen tablets in the detergent isle that foam up and supposedly clean the build-up out of disposers. Has anyone used them, and if so, how do they perform?
Clean Disposers
While I haven't tried those foaming tabs, I do use a cup of ice and about 1/2 cup of Sun Light Dishwasher detergent poured on top. I turn on the disposer until everything is all ground up. I then leave it sit for about 20 - 30 minutes then flush with hot water. This seems to work very well. Also love grinding up some fresh citrus fruit as well.
I am aware that Anaheim made these GE Diposall's. I can only say that I am very happy to finally be rid of it. I still cannot get over the difference between these two machines. When I bought this house the builder had installed a Badger 2 I believe. Having had a bad experience with a Kenmore 1/3hp many years ago I promptly removed and replaced it with a GE/Anaheim. I liked when first installed. The noise did not seem to bother me much either. But then the smells came, and the splashing, and before long I just hated to use it and I love having a disposer. Especially with having a trash compactor. I dont want my kitchen stinking from something rotten in compactor. So I am hoping that this ISE will be with me for quite sometime. I know it is gonna get used alot. Well that is my sob story.
Christopher
foaming tabs
I've used those, they foam up into the other pipes, too, and supposedly cleans them. They seem to work, but no better than grianding ice cubes or citrus peels. Also, every so often, I fill the sink with water, turn on the disposal, and pull the plug.
cleaning disposals
Christopher, et al.
I used the foaming tabs once. Although they work, they are expensive for something that goes down the drain. The dishwasher detergent and papertowels (or ice) seems to work just fine. Although with the Anaheim units you do need to use some bleach, it was the only way I could get the stink out. The plastics parts on the interior scratch from the abrasion during grinding, these scratches collect microscopic particles of food and support bacterial growth. Plain detergent alone (even antibacterial) doesn't seem to do it. Bleach keeps it from stinking for about four or five days.
Never had an odor problem with an ISE unit or a real GE (at least nothing that a little flushing wouldn't fix.), as they don't use plastics parts on the interior.
Barry
thanks guys.
Thanks for your input guys on the disposer. After reading your posts about different models, I really was tempted to go get a more expensive one. Here is how it played out my partner also returned a message to Home depot to have it installed, and all over with before I got off work. So they installed the Badger. Its great we dont use it much. The guys H.depot contracted with installed it did a great job. of course another pipe after 20 some odd years was bad and they changed that as well. We are very pleased with it, its quieter than what was there. 2. No the splash guard is not removeable. It has a 3 yr warranty. Saturday we went and got nice boards and replaced the bottom of the sink cabinet ourselves, Which turned out great. ( no more warped stinky particle board Yay). The little badger seems to meet our needs quite well. Im sure all home depots contract with different plumbing agencies, The techs we had were great. Our little carpentry wood project was done in about 35 minutes, replacing the bottom of the sink cabinet.hope everyone had a great weekend. alr2903.
Disposer hoppers
I have a GE built Hi-Speed disposer that has a plastic hopper.I think these were the last they made.Yes-it does seem the plastic hoppers get etched by the shredded food causing an ideal place for the "scum" to grow.The metal hoppers don't have that trouble.-and even if they did-easier to clean by the many methods shown here.Only metal hopper that could be a problem is the zinc or alumminum ones that can be attacked by food acids.With these you have to make sure the food is completely shredded and flushed away.also the plastic hoppers can be cracked if the machine is fed a large bone or it gets a peice of flatware dropped in it.There was one machine I saw at a swap shop-don't remember what brand it was-only used disposer I have seen sold from a place-it had a transparent plastic hopper.Would have been interesting to see that one work.
Badger disposers
I have used a few of these machines-the only "Builders Brand" unit that really works-the little guys are pretty tough.Used them in the apartment buildings I lived in-they would shred any food waste I had.Even banana skins and chicken bones.Yes-I would imagine the particle board cabinet bottom would be smelly from the food waste and water drooled onto it from the old machine.
banana skins & chicken bones
aren't a challenge even for cheapo disposers.
I first noticed those Badger units in apartments and figured that was the "standard" cost-conscious landlords adhered to. The had no insulation and the lowest powered motors, and it seemed that a lot of them didn't work or people were careful about what they put into them. We had a maid who took bones out of our sink so they wouldn't go into our KM disposer and was amazed when we told her that it was fine for those things to gon into the machine. I said you're used to those cheapie disposers, take a look at this, and showed her our unit under the sink. She was impressed. Our disposer isn't the TOL unit but not far below it, and we/ve never had to use the supplied wrench to unjam anything, and it makes quick work virtually anything we put into it.
Clean it with Ice
Open your freezer, and fill the disposal chamber with ice, and dawn, then add a tad of water and turn her on!
Now for a word of advise,,,,, if you have a vintage disposal, i would not recomend doing this, as the "TUB" / "chamber" may crack! If you have an older but say Kitchenaid/Hobart. Go for it. It you have the new cheezy models, nooooooottttttttttttt, it will jam until hot water melts the ice somewhat.
Happy ice and dawn. AND KEEP THE RUBBER CLEAN.
