What a beautiful dryer!! Thanks so much for sharing the detailed pictures. That sure is some control panel! Is this a machine you plan to use often? Terry
Thanks everyone! Terry, I am not using it much at the moment. I hope to have a black white and turquoise kitchen someday and would like to make it my main machine if I do. It appears to have not been used much. It looked very unused inside. Even the inside of the door looked new where they usually turn colors with use. The switch on the motor that keeps it engaged while running wasn't making contact when I got it. I took it out and cleaned it off and for now it is running like a charm. Now if I can just find both of those dryers a mate!
That is an aweome picture with the control panel all a glow. Will keep my finger crossed that you find the matching washer. Even if you could find the same model and it was white you could always have it painted. Terry
