washermatt
Member
- Joined
- Jan 21, 2012
- Messages
- 13
Hello Again: I recently asked a question about my KitchenAid (Hobart) KDS-16 Dishwasher concerning the interior finish, and appreciate the quick response I received. Now I have two additional questions. The machine itself appears to operate the way it should, with the following possible exception: I have noticed over the years that the upper spray device (a little white rotating device which is attached to the top of the tank), never seems to rotate. While I obviously can't see this in operation because the door is closed, I occasionally open the door during a cycle to see if has moved, and it apparently does not move. While the bottom spray arm works fine, and everything else does, I was wondering whether anybody else has dealt with this issue and what the solution is.
Also, does anybody know whether I can replace the exterior door panel and bottom exterior panel which are both currently almond in color, with stainless steel panels which might be available? Thank you in advance for any further help you can provide.
