More vacuum coffee
Perk never lies. It too brings out the good in coffee. I'm sipping some Pyrex Perked Starbucks right now in fact.
On the FUN factor scale
1. Vac
2. Perk
3. French press
Drip doesn't even count
On the PUT HAIR ON YOUR CHEST scale
1. French press
2. Vac
3. Drip
4. Perk (makes a lighter cup)
I'll go by the FUN scale and say Perk is right under vac as most fun to make coffee.
So I should've said, Vac/Perk rules and drip drools.
I just made a pot of 1/2 Cafe' du Monde chicory blend, & 1/2 Chock Full O' Nuts in my 16 cup stovetop percolator. YUM YUM.
I Like Drip!
I think drip is just okily dokily. The key is to get the grind right, and grind the beans daily. Also, I think the thermal carafe types of drip machines are better. The heating plate on older drip units overheat the coffee, making it bitter after an hour or so. Also important to use paper filters. The drip machines with Melita type cone-style filters are best - they concentrate the grounds under the drip head. The Mr. Coffee flat bottom filter baskets don't get all the grounds as evenly wetted as the Melita type filter baskets. For my taste, the mesh filters - even the gold plated ones - let too much fine sediment through to the final product. Plus, the filter paper is supposed to absorb some toxins that can cause health problems.
Currently the only perk machine I have is a huge Delonghi 60 cup stainless urn. Great for club meetings, the only time I fire it up. It has a glass perk bonnet on top, fun to see the coffee get its full color up there. Other features include a coffee level indicator, a spigot, and a row of lights that let you know how long since the coffee was brewed (the "Freshness Indicator"). It also makes some pretty impressive bumping and mini-explosive noises as it heats up. With freshly ground coffee, makes an excellent brew. Just way too much of it at a time!
Have never tried a French Press or a vacuum coffee maker. I do have a couple of pump-style espresso machines, but got tired of all the effort involved a few years back. But I did develop a good method for getting a perfectly layered cup of latte. I'd steam the milk first, and then layer the espresso on top of it. Looks great in a clear glass beaker.
Louis, that looks great! Glad you're enjoying it. I've been tempted to get one of those a few times. Sounds like Jason liked one he had too. What is that unusual-looking apparatus to the right of the Bodum in the pictures?
Jason, I am drinking Pyrex perked Starbucks coffee this morning too! "Ethiopia Sidamo" it says on the bag. I've been trying to try different kinds. For years I drank nothing but pre-ground Folgers and it's nice to try some new things. I do like this one. Their French Roast is good too, but I think I like this one better.
I finally bought a coffee grinder, and even though it's loud and a little messy, I like having it. I wish the settings were marked for type of coffee though, instead of just numbers 1-23. Just trying to play around with it and figure it out.
My favorites are vacuum (messy but I could do it now that I have a working disposal), perked in glass, perked in stainless.
I've never understood the fascination with the drip makers and why so many people converted to it in the early 80s or whenever that was. I don't really like it and have no interest in owning one (don't like the coffee and they take up too much counterspace and would be too klutzy to try and store), but if I was going to have it, the Bunn is one unit that does a sort of ok job with it. Thermal only though, can't stand that burnt taste of the warmer plate ones, and extra drops of coffee always dripping on the warmer when you pull the pot to take a cup.
Scott, which size is your Pyrex perc? 4, 6, or 9? Also, you take the pump out before you pour the coffee? I've tried but it's too darn hot, to easily catch it with anything, so I just pour slow.
I have the 6 cup. I'd like to add a 9 cup one day too. My mom found this one somewhere and gave it to me. It had the pump but not the basket, and oddly someone had just the parts I needed for sale on Ebay. She had one years ago herself; not sure what ever happened to it, but she mainly uses electric ones. I just had it on the stove for decorative purposes for a long time then recently started using it, and it has become one of my favorites.
Anyway, the Pyrex is the only one that I do leave the basket in while pouring. I don't think it's as much of a consequence with these since there's more room around the basket than on others.
Had a weird thing happen this morning though, don't know if it was an air bubble of some kind or what. It was perking along at regular speed, then there was a loud clank and I wound up with coffee on the stove. It wasn't on high or boiling hard, must have just been one of those things.
Scott,
The unusual-looking apparatus is a Philips Senseo coffee maker. It's a coffee pod machine. I use it for that one cup of coffee that I drink most of the time. It's sort of a espresso machine with a lower pressure.
I agree with Rich that drip coffee can taste good as long as you use a Melitta cone shaped filter. That's the only filter you will see here on drip coffee makers. The flat bottom style coffee makers are no good. Some commercial machines here use it and I never had a good cup of coffee from them. The taste from them seems thinner/lighter. Doesn't taste at all like coffee as a matter of fact. The cone shaped filters do much better.
I tried the vacuum system a few times now and it looks like the taste is lighter than the systems I am used to. Good taste though. I have a percolator too that I haven't used for quite a while. I'm going to try that one out too.
I think we have coffee pod machines over here too, though I've never used one. That's interesting to know about the cone vs flat filters.
I start mine on high and after a few good perks, I put the stove on 3 and just let 'er go.
It's Amazing to see what actually goes on inside a percolator. The steam bubbles form inside the bottom of the tube and forces the water out, and there's a fine line between perking and boiling.
