Morning
Only in an Unimatic
You can see the jets of water shoot up from the sides of the tub before all the clothes are comepletely wet.
Tease is right.....only 11 seconds......I've had other things last longer than that!....
beautiful just the same.........and wanting more!
Well, ya know Jon
so many of us firmly believed that you somehow pulled a rabbit out of your hat, either acquiring or making a golden pulsator. It seemed impossible that smoke stains could paint so perfectly. Then with all of Louis's commentary, it took me forever to accept that the smoke did it.
Only when you showed the big bottom ring where the creases were gray, did I believe. It's too bad you couldn't have shellacked her to keep her gold.
Golden Rubber
You know, I've had old fill hoses for the old Hoover machines do this. They turn a golden sort of color from non-use and as the water soaks back in they again return to the grey color. I wonder if that golden color on the pulsator was nicotine or just the rubber's reaction to being dry for so long. On the 2 hoses I have, no deterioration has been observed, just a color change.
-Tim
