Motor Control Board Fried!
Marky_Mark
Aug 3, 2014
770
Living in Palm Springs and Madrid. From Liverpool.
Hi guys
I'm having an problem where the motor doesn't run at all. I’ve already tried replacing the capacitor and even swapped in a new motor, but neither made a difference.
Upon inspecting the control board, I've just noticed what looks like a burned spot. I’ve never soldered anything before, but I’m willing to invest in the tools and learn how to do it properly.
Is it possible this could be fixed just by re-soldering that joint?
Appreciate any advice—especially from the electronics pros here, like @phillymatt53. Thanks in advance, Mark.
    323.2 KB
    1.7 MB
    1.5 MB
    2 MB
Hi Mark, I guess the first thing I would do, if you have an electrical multimeter, is check to see if there is continuity (zero ohms) between the burned point and the other three points that it connects to.
Actually, I'm not seeing any continuity anywhere on the board at all, so I don't know what I'm doing wrong. It's as though the solder isn't conductive at all! My multimeter does show continuity when I touch the leads together or test something else.
Mark, that board's got Muliple Issues from what I can see.
It appears to be a relay board, am I right?
If you look Closely at all the soldering connections, there are plenty of cracked/loose connections, particularly on those connector plugs.
With a magnifying glass, you'll see circular cracking of the solder around the connector pins, among other bad joints around that board.
While the photo isn't clear enough, I've managed to point out the most obvious bad joints - However, if I were working on that board, I'd go over EVERY solder joint on the board, regardless if it looks fine, and all 3 connectors.
It's got poor soldering and black arcing of some questionable connections.
Make sure you do not bridge closely arranged connections with solder!
A 40W soldering iron and some lead-tin solder should result in a working relay board, IF it hasn't caused other damage to the connected board used with it.
This is what likely causes these "modern" electronic machines to break down.
And it's why I refuse to ever own one.
Hi Matt! Thank you very much for taking the time to do that -- I really appreciate it!
Yes, it's a relay board. Thanks for pointing out the other dubious parts, which I had noticed looked "different" but I didn't know if it was a problem. I'll get a 40 W soldering iron and do my best to fix it. I'll practice on something else first! I'd like to keep this machine if I can.
Mark
    1.7 MB
    2.4 MB
Mark
Good luck, sorry I can't offer any guarentees if it doesn't fix the problem.
Because I do my best troubleshooting on my workbench, impossible through the internet.
Thanks, Matt. I'll be sure to post an update! I've been meaning to get a soldering iron, as my husband has a small portable fan that I want to fix for him (USB power connection has broken off).
Make sure it's a pencil-point tipped iron.
Use rosin core tin-lead electronic solder only.
And don't forget to unplug that washer before anything!
Carefully scrape any blackened areas to allow the solder to adhere better.
Minimize any unneeded flexing of the connector wiring.
And double check for any splashes of solder that may happen.
Slow, careful, patience.
Those relay connectors/wiring have to handle the main power - heavy current.
Thanks so much for those tips, Matt.
"Carefully scrape any blackened areas to allow the solder to adhere better."
Thanks for letting me know. I was going to ask what kind of prep, if any, I should do to those blackened areas.
I've ordered these things, among other helpful bits and pieces. Notice the fun little kit for learning to solder!
    127.1 KB
    144.4 KB
    129.3 KB
That soldering paste won't be needed, because the solder already has a rosin core built into it.
Practice makes perfect!
And DO let us know how things work out. ;)
Hi Mark, sorry I didn’t see the post. I’m still on vacation. I’m up in Maine,
That’s a simple problem just to re-solder that one connection whirlpool clothes dryers do this too. We probably do this repair at least a couple times a month. You simply need to re-solder that terminal on the relay board.
If you don’t wanna fool with fixing it, you can send it to Corcentrics they’ll repair it for you.
Don’t re-solder or fool with any other terminals on this board you’re just going to make things worse fix the problem and go with it.
John L
Going against my professional suggestions isn't wise advice.
So can the hatred where it belongs.... in the garbage.
I can clearly see multiple spots on the board that need attention.
Mark even confirmed the questionable soldering as well.
Repairing only one spot will not insure reliable operation - that type of half-assed service isn't in my book.
And anyone who performs such shoddy repairs is certainly not someone I'd take my stuff to!
Replies 12 & 13. I think you both make good points. I imagine Matt has more practical experience with electronics than the rest of us put together. Whereas I imagine John has more practical experience of fixing washers than just about anyone else on here.
On the one hand, I subscribe to the mantra of: if it ain't broke, don't fix it. So I can see where John is coming from by suggesting I only repair the one joint that is completely shot. Considering my non-existent soldering experience, I might be better off leaving well enough alone for the time being. Especially as the other joints are more closely spaced.
On the other hand, if I had Matt's level of experience and expertise, I would no doubt examine the entire board with a magnifying glass and re-solder all of the suspect joints. I will practice soldering first on the "learn to solder" kit that I bought and then I will decide if I am good enough to try beefing up any of the other joints without doing more harm than good. I think Matt is right that the whole board could use some TLC but I don't know if I am the person to attempt it if not absolutely necessary at this time.
I could send it to Corcentrics, but I think it's about time I learned how to solder. The soldering equipment is arriving tomorrow!
Mark
Mark
Don't worry, soldering is easy.
Let the iron sit on the stand for a few minutes to bring it up to temp.
First, "wet" or "prime" the iron's tip with a little solder, then clean it off, on the little water-damp sponge, this helps to conduct the heat to the connection.
A steady hand, proper lighting, and follow the instruction book if it's got one.
Heat the connection joint, then in a second add some solder, liquifying it, taking care that it only flows and covers the connection like a tiny pyramid shape.
It should clearly bind the wire or connector pin, and flow a little to the copper foil trace on the board.
Remove the iron and let it solidify for a few moments, then do the next one, etc.
The second from the right below is a perfect joint.....
Well, my soldering equipment arrived and so did the practice kit.
I’ve soldered the dry joint and tested the board in the washer and the motor is working perfectly at all wash and spin speeds. So….success! Kind of anyway. I haven’t reassembled the washer just yet and I’m not particularly happy with my soldering skills just yet. I mean, yes it’s working (for now?) so maybe I should call it a day and leave it at that. But I did also buy some desoldering wick and I’m contemplating removing what I did and trying again. But perhaps I should quit while I’m ahead and avoid the risk of making it worse. I dunno.
If it’s just of a case of my soldering joint failing down the line and needing to be redone, that’s fine. But I don’t want what I’ve done to cause the board to overheat and be completely ruined.
  • IMG_2967.mov
    IMG_2967.mov
    25.2 MB
    722.2 KB
    526.5 KB
That solder joint that you repaired, if you look at the board graphics, goes to the Lid Switch - (L/SW), which surely was the cause of the initial problem.
Nice job!..... however.....read on...
Mark, my professonal opinion is to go over at least those two sets of connector pins.
They handle the main power voltages to the appliance
The 8 pin connector, and the 6 pin connector.
They look ready to become loose enough to cause another problem.
I can see that they have obvious signs of solder cracks showing up, and any movement and handling of the stiff wiring harness to them will stress the connectors and bring more problems to happen.
The less you have to go into that control panel, the better.
Please listen to me, and save yourself having to deal with possible issues.
I've always believed that - Do it right the first time, or don't do it at all.
Those connector pins are easily resoldered.
Thanks, guys. I'll leave it as it is just for the time being while I continue to practice my soldering skills and get used to this soldering iron and its temperature control. Then I may well revisit the board once I'm a better solderer! I agree that the other contacts would benefit from being correctly re-soldered.
Matt, I noticed that the failed contact was the lid switch. Interestingly, it never displayed an "open lid" message and it always behaved as though it was spinning with the lid closed, even though the motor wasn't running. And it wouldn't agitate either, even though this machine does normally agitate with the lid open.
Thank you for all your help. I really appreciate it.
Mark
Mark
That's because that relay board sends feedback signals to the CPU board. and any intermittent or compromised connections caused by faulty solder connections will confuse the CPU, and in some cases corrupt it's programming.
The CPU depends on solid grounding and solid 12 volts from the relay board's power transformer.
You don't want to subject the CPU to such intermittent conditions.
Because If the CPU becomes corrupted by improper intermittent "on off" voltage conditions it can be damaged, requiring a new (and expensive) processor board.
This is why I stress the fact of insuring proper and solid connections of those connectors before something that you can't solder happens.
I'm pretty ropy at soldering, mainly because I don't get a lot of practice and I've got a brother whose job was repairing expensive electronic modules, who I can ask to do the more tricky stuff.
I would still solder the cracked solder joints on some of those pins for two cable connectors for the relays. I'd probably also do the relay pad that looks crazed to the left of the one that needed repair.
I can also see that the solder connections of the power transformer look questionable too.
That board in general has sloppy wave-soldering. - I'd do the whole board's pads just to have peace of mind.
The last thing I'd enjoy would be pulling that board out again because of missing something.
Quality Control Inspection must have been on vacation that day.
Yay Mark I’m glad you got that working as I said in my post earlier between Jason and I we repaired at least 100 boards like that mostly on whirlpool dryers and many other brands. GE refrigerators are prone to the solder connection for the relay failing.
I absolutely would not do anything else to that board you risk causing problems. There is no reason to do so.
This is one of the few heavy power joints on this board this board ran perfectly for 25 years. It’s going to get very light use from now on. It’s not likely to ever fail again.
Quality control was very good 25 years ago, but not nearly as good as it is today we don’t normally see this type of failure on newer boards.
John L
Thanks, guys. The washer is now washing perfectly, but it still has a problem when it tries to start spinning. This happens about 50% of the time. It's behaving in the same way as it was before the relay board joint failed.
As you can see in this video, it sounds like a Unimatic when it starts spinning! The machine is drawing just over 2 kW.
I'm not sure if it's possible to tell from the video if it's the clutch that's failing to slip, or the motor, the transmission etc. I obviously don't want to run it like this and burn the board out again!
I did install two new capacitors in parallel a few weeks ago. I also bought a replacement motor that I haven't tried installing yet.
View attachment IMG_2975.mov
Hi Mark, this type of behavior has been an occasional problem with direct drive washers especially it seems with the two and three Speed motor models.
If the extra start capacitor doesn’t work, you can try the motor, but it’s doubtful that it’ll work. You may have to pull the transmission and take the clutch out. Sometimes we modify the clutch so it doesn’t have quite as much grab, there’s several ways to accomplish this for a smoother spin start.
After you get it apart, give me a call. I can give you details of how we do this.
John L
Thank you, John. I'll do that.
This is my first DD machine and I'm very impressed by this machine's capacity and performance, especially with heavy items and large loads or difficult loads, such as duvet covers, that tend to develop air pockets. I never thought I'd find it in my heart to love a DD washer -- loved by some and hated by others. I've always found them a bit too modern, and the frantic chugga-chugga agitation was never my thing. But, having seen what this machine can do, I will always have a DD washer in my collection. Using the fast agitation with a low water level will surely thrash the dirt into oblivion.
Quick update (since @phillymatt53 asked in another thread):
The washer is still misbehaving. I tried installing a new motor, but as John predicted, it made no difference.
However, I did discover that the washer spins just fine when plugged into an outlet closer to the main panel, where there's virtually no voltage drop. But when it’s plugged into an outlet that's far from the panel (over 100 feet away in the casita) it starts acting up.
I tested voltage under load (using a hairdryer). The laundry room outlet only drops from 120V to about 118V. But the casita outlet drops all the way from 120V down to 108V or lower.
So rather than going straight to the (expensive) option of installing a new sub-panel in the casita (which I'd love to do eventually) I'm going to talk to John about modifying the clutch to allow a bit more slip and see if that helps.
Unless anyone has other suggestions for dealing with the voltage drop? Most of my other appliances in the casita don't seem to mind it much, but this washer is picky. Either way, I’ll be getting an estimate for electrical upgrades and preparing myself for the $$$.
Mark
