davetranter
I am considering using a 'brush-type' washer motor (preferably with it's original control board) for a 'non-washer' project. I have several motors and controllers 'in stock', but have no idea which machines they belong to, as I inherited many of them from my 'late' father, who labelled nothing, relying on memory for everything. :-(
All of the controllers I have looked at (old, non-computer, 'rotary timer' types) seem to have about 5 or 6 connections to the timer. One wire tends to set the 'direction', and the others (usually via a single resistor) set the speed. Some have a shaft-mounted servogenerator and use a closed-loop system, others have no generator, and presumably sense current to set speed in an open-loop system. I am seeking general, 'generic' information as to how I can arrange a 'variable speed' drive using one of these motor/board combinations.
I will try to dig out (literally!!) one or two, and try to come up with part numbers in the hope that someone will have knowledge of a particular machine and/or diagrams, which would be fantastic!!
Sorry if this is in the 'wrong' forum, but the parts I have are all 20+ years old, so I assume that the people who will be able to help will frequent this forum. ;-)
Any parts I can't use will probably end up listed for sale eventually. (All U.K. 240V, by the way ;-) )
Sorry for the long-winded post. :-(
Dave T
Dave T
