>> ...after removing the clamp carefully keep the rubber gasket in position (measure to the bottom edge from
>> gasket and above towards upper edge)...spacing needs to be correct for reinstalling the cover properly
You might be better off following the Maytag or Repair-Master procedures for setting the top cover spacing when reinstalling. The reason being, when taking apart an old used appliance, you don't necessarily know for sure that whoever had it apart before you re-assembled it correctly. Measuring and duplicating that flawed work propagates (and sometimes exacerbates) any errors they might have made.
The actual procedure for tub top cover alignment is pretty simple - either setting measured wood blocks on the top of the basket and pushing the top cover down on them to achieve a uniform spacing between the inner basket and the bottom of the tub top cover, or reinstalling the top of the machine cabinet and adjusting the top tub cover up or down to have the prescribed uniform clearance against the underside of the top cabinet opening. Either way gets you to the same result, and after doing it, is relatively painless.
Good luck!
