dustin92
I saw wn ad while scanning Craigslist "Whirlpool washer $50), and decided to have a look... It happened to be a Duet Sport Front loader, but the seller said it gave an error code while washing. I contacted the seller, and asked which codes they were getting- F-20, but they hadn't hooked it up to water, and previously F-21 *or* 22. Well, through the power of Google, I discovered that F-20 is a water flow problem, and F-21 was a completely blocked drain or failed pump. F-22 was a failed door lock. Ok, nothing too major. I asked if they would take $30 and they agreed without hesitation. Went g picked it up, and found it to be in *Really* nice condition, and the house was gorgeous with a long paved driveway. I got it home and unloaded (with help!), and ran a test cycle in the driveway. Sure enough, about 5 minutes into wash, F-20. Ok, guess I need both hoses (was just running it on garden hose cold, with the hot inlet capped). Cancel and drain... WOW is the pump noisy! Got both hoses connected, start another cycle and step away for a few minutes... come back to a washer full of clear water flashing "Sd", and a funny odor around the area. Google error code "Sd", and I discover it is an oversuds or slow draining code.. Cancel the cycle, and it won't drain. Hmmmm ok... Google some more and discover that "Sd" is displayed after 4 minutes of pumping and the pressure switch not being tripped. 4 more minutes and F-21 is displayed, indicating a blocked drain or filter, or a failed . Well it's pretty obvious what the issue is... the pump isn't working. But it worked just a few minutes ago? I removed it and found out why.. the bearings and seals were completely shot, to the point of the impeller running crooked enough to wear through it's bearing plate, allowing water to freely flow into the motor housing, thus shorting/binding the motor. There's my funny odor. I found a new pump on Ebay for $38 shipped, bought it, and it came in the snail mail today. I installed it, ran a quick rinse/spin, and all is well. The pump is very quiet and no more error codes. I moved it in the house, in place of the Frigidaire Gallery front loader, which is getting a tad noisy on spin (bearings), so I could test it with proper hot/cold water and a drain, and so far it works well. Does need a new shock or two, as it's clicking when the drum moves. Bearings sound great, and so far, after 2 clean washer cycles, and two loads of laundry, no more error codes YAY! After I get it leveled and get the shocks replaced, it may actually stay, even though I bought it to re sell. I'm impressed with the cleaning so far, and it actually uses WATER, especially in the rinses (2" or so up the window!), and adds more water until it reaches and stays at that level. The Frigidaire only fills once, no matter how much water is soaked up by the load. I found myself adding water through the dispenser or canceling/restarting several times until all the clothes were wet. So far, a good buy
