My Early Maytag A806 Rework Progress
d-jones
Jul 5, 2011
1,200
Western Pennsylvania (Pittsburgh Area)
So this is it. I started the tear-down this afternoon, and right away I was surprised to find tower clamps installed throughout on this machine. Tower clamps haven't been easy to find for quite some time, so to me that would indicate just how long it's been since this thing had any real work done to it. I'll clean them up and try to reuse them, but no promises. There's quite a bit of corrosion on the base plate that'll need removing. I'll have to see how that goes. I have a new old stock replacement, but I'd rather not use it if I don't have to.
2nd photo - Tear-down coming along.
3rd photo - Done for the day. I've got a bunch of stuff loaded in the trunk to take to work where I can use the sand blaster on some corrosion issues, but for the most part this machine is in descent shape. More tomorrow.
I noticed that little detail on the pump as well. I'm going to clean this one up and try to use it, but that may not be possible. As for the timer, I'm inclined to agree with Dan on this. Mallory timers are more commonly found on the early machines, but since I don't know when Maytag began using Kingstons I can't say if it possibly left the factory with one or not. However, since my two other 70s 806's have Kingston timers I'd prefer this early one to have a Mallory. Bye the way, thanks for posting the link. I should've though of that.
Maytag started sourcing Kingston timers as early as the 00 series machines in the fall of 1961 as well as the 02 line (A302/A502/A702), so it is very well possible that this came from the factory with a Kingston version of the non Suds early A806 2-3182 (dash 1).
Good luck with your restoration! Crossing fingers is it spouse approved when you're finished.
Ben
Stainless steel lint filter
They are rare as hens teeth and a steel motor splash cover.
Never seen a machine with iron stains that bad, diluted Muriatic acid should clean that up.
Definitely worthy of a good refurb. Base plate should be okay after sandblasting unless badly pitted.
I'd bet money it will be fine too. The base on my "free" A408 was in far worse shape, and after 2 1/2 years of use as our primary washer, it has still held together!
For a machine like this, I think I'd take originality over perfection, even if the plate wasn't "perfect" after the sandblasting.
In other news
I was able to spend some time cleaning after work today, so a little more progress to report. The motor shield and the mounting panel for the water valves both had corrosion to deal with, so they got blasted today.
Photo 2 - Fortunately the rust came off easily with very little pitting left behind. The Maytag Gray paint on the underside of the motor shield is in perfect shape, so it's at a paint shop now waiting for a specialist to match the color for me. I've been using Rustoleum Ghost Gray for Maytag base plates and structures, but it's not quite the same shade and has a gloss finish which isn't really correct, so this time I'll do it right.
Photo 3 - This has already been cleaned quite a bit, but some of the crud was being really stubborn, so a quick trip to the store for some CLR, Bon-Ami, and Brillo pads later......
Photo 4 - and finally some real progress. The heaviest crud had collected around the tub light lens for some odd reason, but careful use of a flat tip screw driver blade removed it. Not done yet, but close. There's still more cleaning to be done on this tub cover and I still need to remove that rust spots it has and treat the areas so it doesn't come back.
Photo 5 - The underside had little actual rust, but a lot of staining.
Photo 6 - And it's gone, or at least mostly gone. I'll finish it up tomorrow(hopefully). I had to wrap things up so I could get to the paint shop before they closed.
Brillo pads later..
Brillo pads will scratch the shit out the porcelain.
If "the crud" doesn't clean up with a soft sponge and Bon-Ami it is hard water deposits, use diluted muriatic acid to dissolve, it will save a lot of labor and damage to the finish.
Just a quick note.
I bought some muriatic acid to try and was both pleased and disappointed. Disappointed in that it seemed to have no effect on the deposits I was trying to remove, but pleasantly surprised with the way it obliterated the rust that had formed in a few places where the porcelain was missing. That was a great discovery. As for the lackluster performance on the mineral deposits, does it matter that the bottle I purchased is only 34% Hydrochloric acid? I got the only brand they had in the store (it's made by Sunnyside). Does it come in higher concentrations, and would that make a difference?
Regardless, I'll definitely be keeping this stuff around for rust removal.
The Sunny Side brand is fine and what I've always use.
Be careful not to over do it, muriatic acid can weaken the porcelain. Don't leave it on any longer than necessary and flush well with water.
If its not cleaning some areas that could be hardened detergent deposits or something the acid has no effect on.
Or, you may have to leave it on a little longer and use a plastic tool to scrape stubborn deposits.
Well thanks for trying, Douglas....
but I gave it my best effort with the acid and failed. I don't know what it was that collected around all the little the drain holes, but it took this polishing wheel and compound to finally get through it. I've never had this much trouble cleaning a tub cover before, but thankfully it's done. Now I'm off to the paint shop with the lid to get the porcelain color matched and pick up the Maytag Gray.
It doesn’t look like that much was done today, but this took a while. The front panel was cleaned up and prepped for sanding. The console was disassembled and each of the parts cleaned. The console itself was then polished up, and apart from some minor pitting it came out well. The real pain in the pants was the wiring harness. It was dirty and a bit sticky throughout, so each of the wires was carefully cleaned making sure to leave the wire numbers intact. Each of the tie wraps is located where 1/2 inch gray cloth tape had been wrapped around the harness. That tape was dried out and brittle to the point of uselessness, but with a quick search of the internet I found some new 1/2 inch gray cloth tape to replace it. With any luck the finished harness will look pretty much like the original. I picked up the cabinet paint yesterday after work, then when I got home the new timer was waiting on my front porch. This evening when I got home a set of new Maytag rubber feet was waiting in the mailbox, so things are slowly moving forward.
"That's some of the quickest progress and dedication I've seen on this site in quite a while."
Well thanks, Dan. I guess I'm in a hurry to get this done and out of my friends garage, so things can't happen fast enough to suit me. Now just a quick note. In what can only be described as a stroke of luck, I was doing some touch up painting on the the corporate jet that I help maintain and I had a little bit of paint left over. Just out of curiosity I thought I'd see how closely it matched the porcelain on the chipped top panel. It turned out to be about as close to a perfect match as I've ever seen, so I went ahead and filled them all in. By the time I get a few layers built up and polish it out even with the surrounding porcelain I doubt anyone would be able to spot the repairs. See for yourselves.
[this post was last edited: 4/23/2021-17:34]
A bit more progress to report today.
First, Dan wanted to know the serial number, so I got that this morning. It's 215247DD. Then I was able to further disassemble the machine.
Photo 1 - I got this brake removal tool years ago in case I should happen to need it some day. Someday was today and it was quite helpful. I know some folks don't care for it but it worked great for me.
Photo 2 - Finally free, the base plate has been loaded in the trunk of my car for a trip out to the hangar, along with just about all of the remaining parts.
Photo 3 - Except for this bit here. It'll have to wait a few more days for its turn.
Photo 4 - This was a disappointment. There is corrosion on the polished inner surface of the damper leaving it very rough in a few places. To my knowledge this sort of thing isn't repairable, so I'll be replacing this part.
