My favorite Spaghetti sauce!
Toggles,
If I ever take up meat again and if my honey ever shows me to the door, you've got a 6'2" built-like-a-brick-outhouse guy - me - with his feet right under your table.
Seriously, I use garlic and onion together as do many folks in Italy. I just have never seen the real Italian cooking done with garlic browned at the same time as the onions - it turns bitter.
I always do it separately or throw it in two minutes before the onions are done.
Of course, Italian and Italo-American are two entirely different - and two very good - cuisines. Americans of Italian decent are usually shocked, shocked I tell you when first they vist "the old country". Italy today is about as close to the Italy they expect as Zachery Quinto is removed from Chris Allen in terms of hot and sexy.
But you know that - you've been lucky enough to get to know Greece and the US...and Greece today is a fantastically beautiful (especially the men) country with both feet firmly routed in the 21st century.
> I just have never seen the real Italian cooking done with garlic browned at the same time as the onions - it turns bitter. <
One of the secrets to great sauce is to cook the bitterness out of the garlic, without browning it. This requires about 10-12 minutes, cooked in olive oil on a very low flame.
More than once my folks got occupied with something else while starting the sauce, they always tossed out the entire batch and started over if the garlic browned. Once that bitter taste is in, nothing will take it out.
The other main secret is to find pre-blight, non-genetically engineered plum tomatoes, which is nearly impossible to do these days. By the year 2000, over 90% of Italy's San Marzano vines (near Naples) had been wiped out by CMV (cucumber mosaic virus). A genetically modified tomato strain was introduced that is resistant to this disease, but these tomatoes have a much blander taste than the original. They're nearly tasteless. This is when most producers in Italy started adding other ingredients (basil, citric acid etc) to their canned tomatoes. If a product has one or more of these added ingredients you can be sure it's the newer tomato strain.
Here's a repost of my dad's recipe:
2 lbs ground round
2 lbs "meatloaf mix" (blend of ground beef/veal/pork)
1 lb sweet Italian sausages, whole
4 Tbsp veal gelatin, if available
5 large cans Italian-style plum tomatoes, peeled in heavy puree
5 cloves fresh garlic, minced, divided into 3 cloves & 2 cloves
1/2 cup fresh onion, finely minced
6 Tbsp fresh Italian parsley, minced, divided into 4 Tbsp and 2 Tbsp
2 1/2 Tbsp dried sweet basil, crushed, divided into 2 Tbsp & 1/2 Tbsp
1 Tbsp dried oregano, crushed
4 dried bay leaves, whole
2 eggs
1 1/2 cups bread crumbs, moistened with water
1/2 cup parmigiano reggiano cheese, grated
1/2 cup romano cheese, grated
1 small can tomato paste (optional, if you prefer a sweeter & thicker sauce)
1/4 cup olive oil
1/4 cup vegetable oil
1/2 tsp salt
1/2 tsp pepper
PROCEDURE:
Heat olive oil in medium skillet. Add:
onion
3 cloves garlic
4 Tbsp parsley
2 Tbsp sweet basil
oregano
bay leaves
Cook covered for 10 minutes on a low flame, stirring often, until
onions are clear. Do not brown the mixture. If it browns, toss it
out and start over.
Empty mixture into large (12 qt. or bigger) non-aluminum saucepot.
Empty tomato cans with juice, one at a time, into a blender and
briefly puree. Add tomatoes to saucepot with salt and pepper.
Cover, increase heat to high and bring to a rapid boil, then
reduce heat to medium-low and boil gently for 1 1/2 hours,
stirring occasionally. Be sure to stir the bottom of the pot,
to prevent scorching.
Meanwhile, prepare meatballs. In a large bowl mix thoroughly:
ground round
meatloaf mixture
eggs
2 cloves garlic
2 Tbsp parsley
1/2 Tbsp sweet basil
bread crumbs
grated cheeses
Form mixture into 2" meatballs. Add vegetable oil to large cast
iron skillet and heat to medium-high. Add meatballs and sausage
and brown well on one side before turning. Do not cook completely.
Outsides should be well-browned, but centers should remain uncooked.
After tomatoes have been simmering for 1 1/2 hours, add partially
cooked meatballs and sausage, tomato paste and veal gelatin.
Simmer on medium-low heat 1 to 1 1/4 hours more, stirring and
skimming off excess fat occasionally.
To serve, remove meatballs and sausage to a separate platter.
Remove bay leaves from sauce and serve over your favorite pasta.
Sauce freezes well and will keep for a few weeks when stored in
airtight containers.
so sad
and so true, Jeff.
There are now some decent tomatoes showing up again, but in limited quantities and at prices...well, if the only way to lick this virus is to go further into genetic engineering, we may have to...
Thanks for the support on the garlic!
gods
Louis,
That is food for the gods.
I have a Sicilian friend who does that one. When she is in a good mood, she let's me wipe out the skillet afterwards with a slice or two of fresh salt-free bread she brings up from home.
Sigh.
Pepperoncini peppers are not so easy to get in many parts of the US. You can substitute jalepenos, removing the seeds and freezing for three months first. This leaves the bite but adds that slightly sweet note.
MMM! Oddio che fame!!! E' pronto! A tavola :DD
GREAT!
At end everything is "american" in America but thank goodness kitchen stay ITALIAN! The most missing for who's going to leave from here!!
THANKS! For the good receips either!
Diomede
Diomede,
The Italian-American cuisine is a wonderful one. You will find many recipes and tastes that remind you of Southern Italy in the 19th century.
Somethings are a little hard to get used to - "pizza", "meatballs" and this weird fixation with oregano being the three things which I have never really got used to. They also overcook dry pasta and put garlic cloves through presses like the Germans do. Ugh!
California extra virgin organic olive oils are every bit as good as our lighter ones here in Europe and the Americans have some tomatoes which still really taste like they used to here in the old days. Nobody in Italy does Pizzele as well - the American flour is better for it. Unfortunately, stupid American laws forbid the use of real almond flavors, so anything made with almond taste is, well, never mind. You really won't know it's almond unless you read the ingredients.
What the Americans really need, tho', is some seriously good cheeses. Imported Italian cheeses cost a fortune. I always take my dad some good ones...
Steve,
I'm sitting here at my desk - working on a translation - and eating φέτα drizzled with a lovely, dark pungent olive oil friends just brought back from central Greece...
So sorry, I was so busying chewing, I didn't quite hear your comment...what was it, again?
not with this olive oil,
Two totally conflicting tastes - this is one of those high acid, super strong, pungent flavored oils.
But heh - I did mention that there is a taverna right down the street whose cook fries wedges of kefalotiri and serves them so hot they singe the paper...and we eat them with kalamata olives and peppers and lots and lots of baby octopus in lemon juice and just lightly sauteed on the open grill?
I tried my own recipe (HOW DARING! LOL)with pork spare-ribs. I had to use the slow cooker (since I was at work all weekend) and cook it for 8 hours on "low".
The sauce was deicious and the meat fell off the bone.
In this way, I hope to be getting needed cacium. I bumeped into my old parish priest at a Christening and he is hunched over with osteoporosis.
Thanks Bobbins!
Ray, "large" cans = 28 oz.
It's definitely worth the effort. The flavor is incredible, but the sauce is thinner than what most Americans are probably used to. That's why my mom started adding a small (6 oz.) can of tomato paste to the recipe. My dad and her always argued about this addition.
Also, my dad would usually add braggioli to the meatballs and sausage (same procedure, brown them in a cast iron fry pan, finish cooking them in the sauce), but that's another several steps in an already complicated recipe. It's basically pieces of flank steak that's pounded thin, with chopped parsley, garlic, salt and pepper rolled inside, and tied up with baker's string until the sauce is finished cooking.
Thanks Jeff! I kind of thought that was the size, but wanted to check before I made. I have a heavy 18QT. All_Clad stainless pot for which I will use thie for. I would guess that this sauce would freeze well also?
THanks for such a nice recipe.
So JEff.....I am guessing that you are Italian?
Hi Keven..... In America we would say "Now thats Italian" lol
Now this is the kind of sauce I like to make. It makes a lot and can be frozen in individual containers.
So many people want to take the easy way out, but the taste is not the same. I too at times, use a jar sauce by Barilla which is good if added to chopped meat etc or a lasagne, but nothing beats the taste of a long slow cooked sauce. I am not even Italian, (Polish here), but sure love to eat rally good, cooked from scratch food.
I cook all ethnic foods. I also like German a lot. My favorite is Rouladen, red cabbage with bacon and wine and apples, sauerbraten with home made spaetzle.
Thanks Keven. I can't take credit for my parents' cooking. Both were Italian and both learned most of their recipes (including this sauce) from their parents. I was fortunate to grow up with diverse and pretty amazing food. My dad's family was well off and their cuisine consisted mainly of seafood (pasta to them was what someone ate when they couldn't afford "real" food), meanwhile my mom's family was dirt poor from the hill towns of Naples (lots of polenta, pasta etc), but they knew how to make the most out of simple ingredients.
Hi Jeff. I will let you know how I make out when I make the sauce. My dad grew up during the depression and my grandmother raised chickens, so.....they ate chicken a lot during the week, (Back then this was considered a poor mans food). So when my dad got married, there was no chicken in the house. A lot of beef, pork, veal, and only white meat turkey. Of course, the Polish food, kielbasi, pirogies, etc.
I find that most of the recipes from our grandparents that were passed down throught the family are far better than any found in cookbooks.
Jeff,
I know that one - my dad's family was split along similar lines.
There are so many outstanding cuisines in the European kitchen, but nobody - and I do mean nobody, has the range of the Italian kitchen.
Much as I love Greek food, as a vegetarian (eat fish occasionally) I quickly reach limits there.
Much as I love Polish pastries, there is just no room in that culture for vegetarians.
The Serbian "poor folks" kitchen is pretty accommodating and a good Serbian cook can make you fall in love with their culture and cuisine.
But nobody, and I mean nobody does it like the Italians.
Sigh.
My dear friend is back from Italy tomorrow and has invited me over for dinner, courtesy of her mama...can't wait to hie my inexperienced, untraveled and thus limited palate over for the risotto. She does things with porcini that would take your breath away...
Hey boyz.
What is the equavalent of a 1 cup (8oz) can of tomato sauce?
Only the cheap ones used to add onion and garlic and "spices". Now even the name-brands have this crap in it as well. The manufactures legally can shove a whole bunch of stuff you don't want to eat in the "spice" category.
How much paste or whole tomatoes makes the equivalent of 8oz of sauce?
TYVM
Here is my Great-Aunt Thresa's recipe:
1 piece approx 1 lb beef roast
few pork spare ribs
1 chicken breast or some wings
1 large onion finley minced
4 cloves garlic finley minced
6 quarts home canned tomatoes(this is a must or it dosent taste the same)
4 8 oz cans of Hunts sauce
1 1/2 can tomato paste
bell pepper
carrot
celery
fresh basil
fresh parsley
oregano
bay leaf
brown sugar
white sugar
salt
parmesean cheese
in a large pot add the canned tomatoes, hunts sauce, and tomatoe paste, white sugar, brown sugar, salt, and put on flame.
meanwhile in large heavy skillet slowly cook onions in fat(I prefer bacon drippins)until soft and translucent, add to sauce, then do same with garlic. then season meats with salt and pepper and brown all sides in skillet and add to the sauce. add pepper in 2 halves, carrot, celery, and herbs. simmer for several hours until meat is tender and sauce has thickened some, taste occasionaly and add additional salt as needed. when finished, stir in a hand ful of parmesean cheese.
Aunt Thresa always made this EVERY Sunday for dinner along with her wonderful pies an d bread and either roast beef or fried chicken. She always used the Percitelli#12 noodles, which were like big straws.That is the noodle of preference for me because that is what she always used
My sister is so fat.......
how fat is she?...........
thanks for asking.........
My sister is so fat her blood type is RAGU!
she screams at the microwave to hurry up!
she has more chins than a chinese phone book!
she likes recalling the past, her first diamond, her first husband, her first CHIN!...she hasn't seen any of them in years!
while your having seconds she haing 23rds!
her idea of a diet is leaving the cherry off the sundae!
and, she goes thru the drive-thru at McDonalds to get a burger to hold her over till she gets inside!
I asked her what she wanted on her burger?...she said "a hotdog".....lol
god is gonna get me!
Toggles,
I find that 500 grams of crushed vine-ripened tomatoes, 2T red wine, 2T extra-virgin olive oil, and a bouquet of three garlic cloves, a teaspoon of black pepper corns, six leaves of fresh basil all in a stainless steel mesh ball cook down into a generous 12-14oz. of sauce which I can then either further concentrate or use as a basis for my final ragù.
By the by, even Walmart now has Hunt's free of MSG and HFCS, not that MSG bothers me...But yes, since I don't eat meat, I would like to know what's in those cans and bottles, exactly.
Which, of course, is why the producers don't want to tell you....
Betty Feezors spaghetti sauce
Here is what I use,Betty had a cooking show on wbtv in Charlotte for 24 years...way before food network ,if you go to you tube,you can see one of her old shows.. 2 lb h burger 2 onions 2 g peppers 2 cloves garlic 1 tbsp chili powder 2 6 oz cans tomato paste 2 cups water 3/4cup catsup 2 tsp salt 2 tsp vinegar 2 tbsp sugar brown hamburger and onions,add the rest simmer about an hour,I leave out the green pepper as it is a heartburn waiting to happen...this is the thickest sauce never watery..dosent sound like much ,but try it,its good.
