GMSS96 Single-Stage,
Multi-Speed Gas Furnace
• Up to 96% AFUE Performance
• Multi-Position Installation
It was set up with single speed blower. I ran it again tonight as I was moving stuff in. Temp rise was on par with my current 80% AFUE furnace in my condo. When the output air was cool and all residual heat removed from heat exchanger, it kicked off.
What I have learned is when you call for heat like I did, say from 60 to 70, it does not come on right off the bat. First the direct vent blower comes on, runs for a bit, then you hear the ignitor kick on, flames start and shortly thereafter, the blower kicks on. I'd say it is about 75% of the time my current old school furnace takes to go from not on to the blower kicking on.
It is a 60,000 BTU output with a max temp rise of 65 degrees at 1200 CFM blower setting. I suppose it is sized right for 1024 SQ of living area. My garage is not heated due to building codes.
Bottom line, while the temps here have moderated, it does warm up the place quickly. Due to 2 intake grills in the living area, it is a tad noisy but noise from each vent in the living areas is virtually nil. Noise in the utility area where it shares space with my union made Bradford White WH is about the same as what I have now.
Heat exchanger is lifetime warranty
10 year warranty on the whole unit
10 year warranty on replacement of whole unit if heat exchanger fails. Which is kind of weird due to #1 above.
Since this is my very first hi eff furnace, I am certain there will be nuances that I will have to learn. Like the delayed start of the burner ignition.
I like the Aprilaire t-stat. Whilst it is not programmable, I like the fact it lights up then a button is pressed and has a nice large uncluttered LCD display. The buttons are soft touch as well; this lends an air of quality (even though the unit is probably made in China).
