New Microwave!
Microwave ovens without start buttons
In my experience, only a few of the very earliest microwaves did not have a start button, it’s probably a UL requirement.
You should never use a metal shelf in a microwave unless you’re cooking two large plates of food at the same time it is not intended that you leave the metal shelf in it when you’re cooking just one item, it leads to uneven cooking, and it can start arcing at the shelf brackets and causes a small fire.
I have found in general that the larger the cavity of a microwave oven, the more evenly, it cooks. There’s just more room for the microwave to ricochet around as it finds the food.
Waiting for some cooking videos chet to show how evenly your new microwave cooks. You can also do speed test by using a liter of water and see what the temperature rises over given amount of time. These are the proper ways to assess evenness of cooking and heating speed, with a microwave oven.
Combination convection, microwave ovens, unfortunately are too slow in the US because there’s not enough power in the outlet to run the heater and the magnetron at the same time so they’re a bit of a compromise. This is one place where the European ones work faster because there’s more wattage available in the typical household wiring.
This was why the advantium 240 V unit was so good it had nearly 600 W of halogen heat combined with 900 W of microwave power if you ever get a chance to use one of these, you can do a lot of cooking fast .
I think I found the best oven
I did boil water in a tall glass cup (about 2 - 2 1/2 cups water) for tea- in 1 minute and a half it was boiling. Sharp here again heats faster than my GE overall, and food evenness is just unreal. Not just evenness but food does not look like its microwaved at all.
I keep forgetting just how strong this microwave is. I heated 18.8oz of Campbell's chunky soup for 3 minutes by accident yesterday and while evenly heated it was way to hot to eat. I had to transfer bowls and let it cool down. On the GE the soup would be warm in the center, crusty around the edges and the bowl so hot you needed gloves. Often I'd stir the soup, then let the heat from the bowl transfer into the cooler soup. If I had limited time I'd pour it into another bowl and heat it again, and the heat from the first bowl drying the residual soup to the side of the bowl.
The more I use the Sharp the more I realize I may have bought the best microwave that money can possibly buy in 2023. The only other unit which just might exceed the Sharp in terms of even cooking is the Panasonic NE-1025F based on various customer reviews on Youtube and Amazon:
https://www.amazon.com/Panasonic-NE...8e6d374b3&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&th=1
However, the Panasonic may not be as well designed our built as the Sharp. For example, the cavity air is exhausted out the left side into the interstitial space (with limited venting on the external wrapper) where in theory moist air can accumulate condense on internal surfaces and parts. On the other hand, the Sharp has a dedicated wide open vent in the top rear which exhausts directly to the outside. Its external louver even say do not remove to prevent RF exposure. Interstitial spaces between the outter wrapper and cavity wall only see fresh dry air. The Sharp is built to exhaust food moisture and odor right out the back with great air turn over.
Also, on the Panasonic the control board seems to have just one large relay for the MOT and a small one for the fan and light where as the Sharp has a large relay for the fan in series with another large relay for the MOT.
I'm sure I could find more flaws if I could test the Panasonic.
Internet pic showing the cavity venting of the Panasonic NE-1025F:
As an Amazon Associate we earn from qualifying purchases.
Oatmeal with flax seed. Never been this fluffy!
I'm having to much fun with this. I'm going to buy tons of microwavable items today! Packets, burritos, soup, frozen meatballs, entrees ect.
Screw all the Breville roasting and pan Frying.
Its the small things too
Just noticed that taking a pic of the back vent even the fan blades are rounded. The more I look at this oven in granular detail the more I see intelligent quality engineering spanning from the micro level to the macro level. Its just not what I normally see, far from it. Everything is so well thought out.
Can't say I've seen many microwaves with rounded edge fan blades.
Serious engineering consideration went into all aspects of this oven. Literally all appliances should be like this.
Thanks!
Even though that and our other Amana aren't my favorite (there's a couple of newer Amanas that I liked better), these are just built like tanks! So here's our other Amana that's in storage, still works like the day it was bought brand new, just only replaced the light bulbs in it's entire lifespan. It's a little harder to see the info sticker since this got used alot more than the other one. It was made in 1993 and it has 1800 watts, that would explain why this one heats up better since the other one is 1500 watts. One of my local sandwiches shops had a few of these before I mentioned about earlier, they've since been replaced by the commercial ones. I also have a couple neighbors that had the white version before which I think doesn't look as pretty as this black one in my opinion. Anyways to answer your question about the metal rack, to be honest, I couldn't tell the difference between having one on versus not. I didn't realized from John that it can be used to heat two things at once. I was thinking the rack makes heating better and it can be taken out if you put something very large inside. But again, I couldn't tell. However I do know for certain that we've hadn't had any arching problems. We did had some metal items spark inside before by accident like tinfoil or forks but never from the racks. I was just talking with my mom about both of the Amanas. When my dad is gone, she'd rather not have the Amana back from storage. She'd like to get rid of the Toshiba and just make another cabinet with a shelf inside since she'd like to have more storage space and she'd feel like she doesn't need two microwaves anymore for the kitchen. She'd also like to do the same for the basement as well since we rarely use that microwave so I'm planning on claiming the two Amanas, either keep them as a collection or just sell them off.
And here is our High Pointe in the trailer. It's alot smaller that I realized. I remember our Magic Chef and Dometic we used to have were more bigger for being a compact size.
Keep the Amanas, there is nothing like them today. In fact those single dial 1980s JCPenney micros literally had thicker metal for their frame and a door to replace the cavity bulb. Nothing today comes close.
We'll see
I'd like to keep them as a collection but if I won't have room for them left, I'd part ways with them. I know I don't need either of them plus neither of those two are my favorite to use anyways. And not to mention I'm not a fan of microwaves at all in general, I'd rather reheat some things up in the old fasion way. But if I could keep at least one microwave out of all of the others that's ever been sold in the market, my grandfather has a Sharp Carousel that I'd love to inherit when he goes. Not only I think it's very cool but it also outlived the original microwave that was there before which I believe was an Amana because I remember the clock display being red.
Internals
Not my video, rather one I came across showing the insides of an identical model. I must say, I don't think I have ever seen a modern microwave this thic, full and meticulously thought out except perhaps for a few residential models from the 80s. The air intake duct and fan duct like incredibly over engineered, the bracing, fabrication, magnetron mounting, wave guide, ect is all over engineered. The transformer definitely appears larger. Nothing inside resembles a $300 microwave, far from it- more like an $800 commercial model. All microwaves should look like this.
Word of caution- never get so close to an operating magnetron, capacitor, secondary leads or step up transformer like this guy does in the vid. 4-6kv can arc some distance and unless the HV cable has a legit concentric neutral I'm going to assume that HV "insulation" (more like covering/weather proofing) is not up to dielectric snuff. (And even then unshielded medium voltage cable can still have an electric field around it capable of exerting a perky surprise)
By comparison, a glorified Breville:
To add, my Sharp also has a soft close latch. So the Breville really has nothing to brag about.
I'm truly in love.
