wire-weaver
- Joined
- Mar 1, 2008
- Messages
- 5
Hi folks,
Chris and Philip (Premier500) made some interesting comments in a prior thread (ref. link below) which has lead me to ask for help.
I have a Hoover Premier 750 Washing machine, and have replaced a lot of parts in it myself over the years. I'm not about to let the latest fault put it into retirement.
Here are the symptoms:
Spin cycle works OK, however the wash cycle only rotates the agitator in one direction, and when it should be rotating in the other direction, the top of the brake arm skips across the teeth on a cog on the outside of the gearbox and makes a clicking sound.
Also I'm not sure if this is normal or not, but I can see that when I manually rotate the agitator in one direction, the brake arm engages OK in the brake band, but when I turn it in the other direction, the brake arm doesn't engage and slips out of the brake band which results in the clicking sound as the plastic top of the brake arm slips over a gearbox cog.
And as Premier500 has already mentioned, the clothes indeed get wrapped around the agitator, making it go out of balance for the spin cycle.
So can anyone tell me which bit is bung ?
thanks in advance
regards
Peter
http://www.automaticwasher.org/TD/ARCHIVE/MODERN/2007/13034x13.htm
thanks in advance
regards
Peter
