my little laundromat
electroluxxxx
Jan 14, 2008
156
Syracuse NY
I know it isn't much but over the past few months I have acquired some wonderful machines. with the help and advice of some of the members here all of the machines are up and running as they should with the exception of my Easy Spindrier (not pictured) as that is the next thing to be gone through. my goal is to find the matching A806 washer to go with the dryer and I also have an earlier model 142 from 1958 that will be either restored to the best of my capabilities considering it is in rough shape or I will use it as a parts machine for my 142 that is currently in weekly use.
thank you guys!
yogitunes, yes it is zigzagged like that for now until I put a T splitter in so I can vent 2 dryers. eventually i will be hooking up all 3 dryers and all 3 washers I have but for now i just have the 142 and 642c in operation. my plans are to move the machines into my "back room" in the basement and finish the basement that you see, as it is a full basement. In order to have everything take place I need to insulate and redo the ceiling in the back room, run plumbing, electrical and ventilation for the dryers not to mention a double utility sink ( which i have). As we all know things like this take time and sadly I don't have much time, so for now im going to run another 220 line and add an additional drain pipe and utilize both sets of machines that i currently have.
You might be better off just running separate ducts. I researched the "2 dryers / 1 vent" option for my own machines, and quickly decided it would be easier, safer, and cheaper to just run a second vent through the wall.
With two machines on a Tee (or better at least, a Wye), some amount of air is always going to be blowing backward through your other machine(s) instead of out the vent. This means you are pushing lint and humidity into the exhaust and blower assemblies of your machines, which is obviously not good for safety or longevity. (It's especially bad for gas dryers, as you create a path for combustion gasses to be blown back into the living space.)
The obvious solution to this is to install check valves... but the typical "draft stopper" style are prone to collecting lint, and may be a code violation to install in this way. There is a different style for multi-unit apartment buildings and the like, but they become more costly. You also would need to cut a larger hole in the wall and use a larger exhaust vent and pipework after the join, as a 4" vent is only suitable for a single dryer. And there's no way any of us would only use just one dryer at a time if you had multiples hooked up!
To me, cutting another hole for a second dedicated 4" vent made the most sense, and it's much easier to stay safe and compliant with the codes that way.
yeah...been there.....multi ducts into one 8 inch main duct...
first, just free flowing of sorts, if their all running at the same time, your good, but if one shuts off, the air is blown back into that dryer(s)….
second, I installed dampers from each unit......and true, they required more maintenance/clean out....
third, and found it best...as mentioned, a separate vent for each unit....
keep in mind.....3 or more dryers venting outside....that's a lot of air coming through the house.....especially robbing your conditioned air....on the good side, it will pull fresh air into your basement....
Thank you all so much for the wonderful compliments and advice!!! For now I am going to try the dampers, I clean out the dryer hoses every 3-6 months and inspect them regularly. I have found out that I actually have less lint build up in the vent with the maytag dryers than I had with the whirlpool ones I had. I also have noticed that the dry time on the HOH model dryers is actually less than my previous whirlpool dryers and also my westinghouse "spacemate" dryer. not to mention the electricity usage seems to be a little less too so rather efficient and I love that! Maytag machines have always seemed to be extremely reliable and seem to be such simple machines with little to nothing to really go wrong. I have replaced the injector hoses on both washers, cleaned out both valves and reassembled them, the motor on the A502 has new springs and glides and the 142 although used much more in its previous life seems to be fine in the way that the motor glides on its track and the tension still seems perfect. unfortunately I am not able to get the agitator out of the A502 to clean out under it due to the hard water in the previous house. so any pointers on that would be great because I really don't want to break it.
I figured I’d start off the new year on the right foot and hook up the A502 along with the 142. I did the maiden wash today and this is the first time it has been used since replacing the parts mentioned in the post above. The issue I’m having is that when it goes into spin the motor sounds like it’s ramping up and then trips the thermal cut off for at least 30 secs, it seemed to spin out fine on rinse however when it went to do its final spin it tripped 3 times and the load wasn’t uneven nor was it overloaded. I’m guessing I may have to either adjust the pulley a little bit or put some petroleum jelly on the glide track. I did use a little 3in1 when reassembled the motor glide assembly as I read somewhere not to use grease.
Could someone please shed some light on this? It didn’t trip before I replaced the glides and springs, then again there was nothing left of the old glides and the motor seemed to want to bounce around. Also the belts seem to be pretty tight, the pump belt tension is so/so and I know it usually is supposed to be somewhat loose.
Anyone have any advice? Correct me if I’m wrong but If im not mistaken the motor is supposed to slide back and fourth during wash operation and stay still during spin.
