My new AEG from 1969?
So, I'm assuming that the only reason why you'd want to use a Biological wash is if you are using wash powder (Detergent) which says "Biological" on it?
What happens if you use Biological Detergent on a regular cycle or use regular detergent on a Biological cycle?
This is kind of a new concept for me as I've never heard of this before.
Biological detergents contain enzymes that break down organic stains much more readily. One of the first detergents was Procter & Gamble's Ariel in 1969. A detergent with enzymes cleans more effectively than non-bio detergents.
Euro automatics were hot & cold fill. Now they tend to be more cold fill only.
Special "Bio buttons" on the washing machine usually either cause the machine to fill with cold water and heat it slowly, or else add a prewash that is cold fill and slowly heated to 40°C, before a normal "hot & cold fill" mainwash.
Furthermore, if a housewife used non-bio soap powder most of the time, she could use a biological prewash detergent, like Biotex, in the prewash.
Many european old machines had a "bio" programm. It could be a longer mainwash, or an extra soak during prewash. Modern machines and modern detergents need to be "biological"
