Hey...
My LG was the WD1411 washer-dryer combination, 8 kg wash/4kg dry. Served me really well except for hassles with spinning unbalanced items, large chunks of fluff finding their way into the shower spray nozzle which then required the top coming off to remove the feed pipe and unblock it. The entire control panel needed replacing as one button stopped working - the start/pause button. The power unit also failed the very day after I ordered the AEG's , luckily all repaired by a maintenance plan. I found the condensor drying rather hot even on the low heat settings and only used it for sturdier items like towels etc. I had this paired with a very basic vented dryer that cam along from South Africa (local company called DEFY that make fairly sturdy but basic appliances) when we moved over in 2004. Had an LG 7.2 kg "intellowasher" over there for a few years with paired with basic Maytag 10kg toplader with matching 10kg dryer, also fairly basic/ brutal but effective, the toplader liked banging the inside cabinet on unbalanced spin, something that never seemed to happen to mums speed queen which a after many years service was irrepairable so I gave her the LG front loader when moved to the UK, she loves it, it has had some fairly major repairs (my dad is very handy) but is still running after 12 years amazingly, I get my laundering-till-u-drop thing from her. I was amazed at the range of appliances in the UK, in South Africa only gets very few of the entire range, people do not seem to be too fussed about laundry as it is usually left to the domestic ladies who use whatever machine is provided (usually cheapest with largest capacity - the lg and Samsung agitator-less top loaders are popular - personally cannot stand them having used some, inferior washing ability and waste water....in my opinion tho...)
I was not even considering AEG when I started my search as I wanted german built/assembled appliances only, but they kept catching my eye on the various sites hence I started researching them. I wish my utility room looked as nice as that pic. Those models in the pic are the on step down from top of range with the narrower display and the white doors. I like the white doors and almost went for them but really liked the idea of the weight sensor in the TOL models. I could perhaps order the white door parts, checked on the AEG spares site and they were quite reasonable. I was initially going to get the washer-dryer and pair it with the heat pump dryer (washer dryer also has narrow display) but decided against that as the conventional condensor utilises too much water and electricity, I do miss being able to wash and dry in one go overnight tho....maybe I will still add it to my current 2 if I can find space! Lol
