My new LG 4000 series washer and dryer
I did not buy an extended warranty, but when I bought my set in April or so, LG offered a double (2 year) warranty if they were registered within a few months. I signed up; it didn't affect my decision to purchase and hopefully I won't need it, but it's a nice peace of mind perk I suppose.
Mike, I have used the Denim and Full Load downloadable cycles thus far and AI indicator came on when I pushed start and stayed lit even on the heaviest soil setting.
Water Temps
Nmassman44, Powerfin64,or Appnut
I recently purchased a new set and waiting for delivery, so are all the programs on the new 4000 series with dumbed-down water temps, would hot be the new warm, warm cool, etc?
yes. If you want a HOT wash, use the extra hot water setting, on the cycles that available for it. I really like my set. I use most of the water temp choices. which LG set are you getting?
Rich is correct. Allergene and Sanitize will get you higher temps, in addition to extra hot on Normal and Heavy Duty. On Perm Press, Bedding, Towels, and Whites hot is 112F, warm is 89-92F. For Normal hot is 95F to 104F and warm is 82F to 85F. Steam option on Bedding and Whites will get you temps ranging from 145F to 160F, depending upon load size.
Ok Good to know
Thanks guys :)
Powerfin64 I'm getting the 4100HBA washer and DLEX4200B dryer. I had ordered another set and found out it was cancelled. Most appliances are either delayed until dates like August 27th or temporarily unavailable and price have jumped up $100 per unit on a lot of them. Complete madness!
@appnut
Bob, I meant to tell you I eventually ran across the video of a blind lady, I think she was the same woman you mentioned to me a month or so ago, Lucy somebody, who owned a wifi connected LG washer and dryer, either the same or very similar to what is being discussed here. She worked with LG on beefing up their laundry app to make it usable for visually impaired folks. It's actually really neat and makes me less intimidated about getting a new washer and dryer should the need arise. These are definitely the machines I would look into if I had to buy new. I think she said they made a Braille overlay for her as well so she could use the touch screen on the machine itself.
A former member who has kept in contact with me over the last 10 years. He's had numerous LG FLers over the years. He knows how much I like to know what's going on with cycles and provided me with the basic information. I've been able to answer a couple of questions he has had about LG washers he wasn't sure of, but given I've been known to sit in front of my machine for hours and keep track of monitoring temperatures as the rise and fall with the combination delay wash & temp buttons at the same time. I've always known there's a reason why the comparable sized Whirlpool & Maytag Energyguide rating is 54 KWH/year more (159) vs. LG's 105 KWH.
Bob is getting his details via observation.  Pressing/holding Delay + Temp while the machine is running gives an instantaneous display of the thermistor reading (is it °C or °F?).  Delay + Spin Speed gives RPM.
Other LG models may provide the info via other button combinations.  I ran across this YouTube vid on which whatever model is involved apparently is via the Temp + Spin buttons for RPM, Time Saver + Temp for temperature.
The temp readings are in Celsius. I just ask Alexa to convert them to Fahrenheit. So far these machines have not missed a beat and are outstanding in performance. I did see in CU that this set was highly recommended as the top set. Overall I am quite pleased with them.
Mike, notice my figures quoted are in F not C. On Whites and Towels (with a heavy load), once the 112F is reached, the heater turns off and does not come back on, regardless of how much the water temperature decreases. And with my water heater set at 120 or so, for a large load of towels with a lot of hot water added for the wash, 112F is reached between 5 & 10 minutes after fill is complete. I've only been able to get up to between 147 & 151 on Sanitize with a large load of towels and Allergen is maybe 4-5 degrees higher. The respective heater thermostat cut off for the two cycles is 158F and 163-165F. Most of my usual daily laundry is fine in the new machine. But my most challenging loads have ended up requiring some button pushing to get the results the Duet gave me due to better time adjustment for large loads as well as a true steam generator period after wash water was drained and up to 26 minutes of steaming that really raised wash tub environment temperatures. But it's also a problem in Europe with eco60 cycles that don't reach the temperature they are supposed to because of programmed energy requirements. I am very thankful for a machine that allows me to have some control over hot water temps (and even some warm too) rather than accepting the dumbed down energy star requirements. I won't use warm on Normal, 86F I don't even consider warm. If I want somewhat of a warm, I'll use PP. If I want an old-fashioned warm of 95-104F, I select hot on Normal.
Extra Rinse(s)
Does the newer LG series give you the option of having more than one extra rinse? If so how do you get the machine to do that? I haven't received mine yet as there is a delivery delay from LG, apparently delivery delays are now the new normal as a result of the pandemic.
Yes. With TurboWash on, cycles such as Whites & Sanitize (and maybe Allergene) have a default of 2 rinses and can add up to two additional. Other cycles (such as Normal & Heavy Duty, Perm Press), have a default of one Turbowash rinse and can add up to an additional. Me personally, I always ad an additional rinse, regardless of whether I have turbowash on or off. thus far, the maximum number of rinses I have counted with TW on is 4. If TW is off, I believe it's a maximum of 5.
