My new Radarange!
I also believe the foot on the back of the unit also acted as a spacer to ensure the air port on the back was not blocked from air flow. Air also exhausts out of a vent below the controls on the bottom of the unit. Later units (starting with the 4 series) had the vent built into the top of the control panel.
Ben
I guess these changes happened at the same time they covered the grille in the door and they changed from a motor-driven stirrer to an air-driven stirrer.
I just ordered a glass tray for it on eBay. With the shipping, it will cost more than the MW itself... But it won't cost more than visiting all the thrift stores in the region again for one of these (I already did it!).
I just hope it will get here in one piece!
The only microwave oven I ever had with a turntable is the Hitachi in the picture above (which I don't use much). All the others had none and I never had an issue with that.
The only problem I had was with blocked stirrers in the "newer" Amanas with an air driven stirrer which caused hot spots. Once repaired, they heat more evenly.  To anyone who still uses their RR4 or newer Amanas and that noticed it cooks very unevenly, I'd suggest to look at the stirrer to see if it moves while the MW is operating. You don't see the stirrer itself but you can see it's shadow moving on the white splatter shield when the light is on. If it doesn't, chances are it's blocked by the splatter shield that has distorted. To easily fix that, simply remove the shield and cut about ¼" of the aluminum blade where it contacts the shield (that should happen on the part of the shield that goes up near the light bulb at the back of the oven.
<h1 class="it-ttl"><span style="font-size: small;">Phil,</span></h1>
<span style="font-size: small;">On eBay now...is this what you are hunting?:
</span>
<h1 class="it-ttl">VINTAGE AMANA RADARANGE MICROWAVE Rectangular 15" Glass Tray Plate platter</h1>
<span id="linkTopAct" class="watchlinkSpan "> <span class="watchPipe">|</span> <span> Add to Watch list</span> </span>
<h2 class="si-ttl">Seller information</h2>
<span class="mbg-nw">arstart2002</span> <span class="mbg-l"> (339
)  </span> <span class="mbg-l"> </span>
100% Positive feedback
Save this seller
See other items
<form action="http://offer.ebay.com/ws/eBayISAPI....8&pt=LH_DefaultDomain_0&fromPage=2047675&fb=2" method="post">
Item condition:
Used
Time left:
<span> <span class="tmlHt">3d 07h </span> <span class="vi-tm-left"> <span>(Sep 26, 2012</span> <span class="endedDate">15:19:15 PDT)</span> </span> </span>
Starting bid:
<span id="w1-13-_bidPrice">US $5.99</span> <span> </span> <span> </span>
<span> [ <span id="qty-test">0</span> <span>bids</span> ]</span>
Place bid
Enter US $5.99 or more
Price:
<span id="prcIsum">US $11.99</span> <span> </span> <span> </span>
Buy It Now
<span> Add to cart  </span>
<span id="atl_btn" class="drpdwnBtn vi-VR-lst-XL"> <a id="atl_btn_lnk">Add to Watch list</a> </span> <span id="atl_arr" class="drpdwnIn btn-split-lg vi-VR-lstIcon-XL"> </span>
<span class="bmlDispMsg"><span style="font-family: Arial, Helvetica, sans-serif; font-size: 13px; color: #333333;"> Get more time to pay with Bill Me Later</span></span> <span style="padding-left: 5px;"> See terms </span>
Shipping:
<span id="shSummary"> <span id="fshippingCost" class="sh-cst"> <span>$11.99</span> </span> <span id="fShippingSvc"> Economy Shipping </span> <span> | </span> <span> See details </span> </span>
Item location:
Hacienda Heights, California, United States
Ships to:
United States
Delivery:
<span id="delSummary">
Estimated between <span>Wed. Sep. 26 and Wed. Oct. 10</span><span class="sh-bubble"> <a id="hldhlp" class="sh-qmark"> </a> </span>
</span>
Payments:
, Bill Me Later<span> | See details</span>
Returns:
14 days money back, buyer pays return shipping | Read details
<span class="vi-g-btn"> Learn more<strong class="g-hdn">about eBay Buyer Protection - opens in a new window or tab</strong></span>
</form>
ed about this item.
There were quite a few on eBay when I checked but none available to Canada... I emailed one of the sellers who accepted to ship it here. If you still have the link, you can still post it! It might serve other members or even myself if it's cheap (I have 3 ovens that use these so having a spare isn't a bad idea!).
Really?
Can you post a picture of it and of the serial number? It would be interesting to know when they started to add that!
Is the control panel on yours painted in the same gray as mine or is it darker? I have seen some ads featuring RR-2s that seemed to have a darker panel. Maybe it's just in ads...
RR-2 with motor-driven stirrer. The shield in this one is semi-transparent rather than more opaque white and there are no vent holes in it. It's also held by 7 screws instead of 4.
[this post was last edited: 9/24/2012-00:34]
I'm still waiting for the glass tray for the RR-2 but this weekend, I decided to follow the repair procedure on Cory's website for one of my other microwaves. My Frigidaire RCM-10 microwaves are almost identical to an Amana RR-9T (or RRL-9TA) and the touchpads and digital displays on both of them were a bit erratic. One of them became worse this week as it was constantly displaying "4"s even if I didn't touch the touchpad (the other does the same if it gets very humid inside). I bought 2 of the 3 capacitors that often fail in these this morning and I replaced them. The touchpad works nicely again! Now, I need to find the other capacitor and I'll replace it too as well as the 3 capacitors in my other RCM-10 oven.   Thanks to Cory's detailed explanations, it was an easy job!
Hi Jon,
The model and serial number tag should be under it! I would be curious to see the serial number and as many details as you could provide!
Please send more pics!
Here's the sticker where yours has a buzzer switch on mine.
Phil, glad the cap replacement was successful! Stunning machines!
Regarding the buzzer switch...I should check my RR-2, but I don't think I've seen one without it. My RR-8A still has the cutout for the switch but that model uses a bell. However my 6W (the first digital machine) uses that switch even though the 'buzzer' is a much nicer electronic beep (quieter than the later ones) that times out after a few seconds. The switch completely disables it. Odd really. -Cory
