danemodsandy
For John (combo52)
John:
I found the answer on the aluminum burner bowls. This is from the 1966 P*7 Use & Care Guide that is downloadable from Automatic Ephemera, on Page 6, in the section beginning "Parts of the Range which may be cleaned during P*7 automatic cleaning." The underscore is added:
"b. Aluminum reflector pans found under surface units. Wipe off boilovers not stuck to pans. Place pans upside down on shelf at Position C. Some kinds of soil may require more than 2 hours to remove. See cleaning chart in Care Section for other ways of cleaning reflector pans. Also see heat settings on Surface Cooking Chart to prevent boilovers. Aluminum reflector pans cleaned automatically may soften and change in color. Replacements can be purchased, if desired from your GE dealer."
So, it seems the P*7 cleaning temp was known to have an effect on the pans. BTW, the P*7 Use and Care Guide covers the TOL 40-incher and the TOL 30-incher of 1966. The 30-incher shown is quite similar to the range I now own, so I got a trove of info that I can use until the frabjous day the exact manual for my range turns up. This makes about the fourth time that Automatic Ephemera has been able to supply a HTF manual, or something close to it, for a new vintage appliance in my house.
John:
