blockeight88
On how to keep washer from vibrating. My home sits on top of a crawl space and was built in 1957. So the flooring in the laundry room isn’t that great. So what I thought was the solution was to put two wood blocks between the dryer and washer in opposite sides using the wall and furnace as supports. This helps tremendously with vibration. Unfortunately the block is indenting the side of the washer. Obviously this method is frowned upon but I’m not sure what else to do except live with it.
The washer is level and rubber vibration pads don’t work. I will post some pictures later on. I will show a video of the washer vibrating without any supports.
