pliney
Can I buy from someone or can you point me to where to find a gasket for my KDI - 18 Imperial? I decided to replace my KA Custom 21 that kept trying to drain with this one I was given as a back up. Unfortunately, once we got it hooked up, water started coming out the bottom of the door. A quick search found a broken blue gasket. I checked my Custom 21 and a slightly newer Kitchen aid and 2 other ISE machines I have for back up and they don't have gaskets. I guess the design is just slightly different that they don't need one? In any case, I tried removing the gasket completely with more water coming out. So I'd love to find a replacement. The other question is, what is the best way to install it? Through the side where you can just see the hinge mechanism without taking anything a part or by taking the whole door a part. I broke the gasket further when I removed it, so I'm guessing it may not be that easy to put a new one in. It's a great machine, looks hardly used so I'd love to get it running. Otherwise, I guess it's on to the slightly newer KA and hope it works.
