cehalstead
Both of my Maytags drain into a laundry sink. One's drain hose hooks over the sink edge. The second one's drain hose won't stay, so I have hooked a piece of plastic sink pipe to it so it can drain right into the sink at the bottom. I had plugged the sink to catch the water from the hooked one's load. The second one started agitating and I noticed that the water level continued to rise. It was "backwashing"?? the water from the sink into the machine. Did I discover a method to create the suds-saver from nothing? Will doing what I have described harm the second machine? I sure would like to keep doing this, as water rates here are going to increase by 15% at the end of the month........
