Neptune Stacked Conversion?
domer2x
May 17, 2006
We have a Neptune washer/dryer set. Just moved to a new house and would like to use these in a stacked configuration. Is there a conversion kit of some kind available to relocate the controls to the front? Thanks.
From someone called
I'm afraid there is no such thing. Maytag built the "SuperStack" for such instaillations. Do you have the space to use the Neptunes separately? If not, probably best to try an ad in the paper or give to a relative.
ALthough I am Nep, you may want to consider the stackable Duet or if your family is small, a stackable Frigidaire. Neptunes have had problems with mold that I expericenced firsthand.
Nep
If you have the newer Neptune, the ones made by Samsung and with a window in the washer door, than you *might* be able to stack them. Contact your dealer for more info.
But no, the older Neptune, made in the USA, with the solid door, that model cannot be stacked.
