the machine is either 3 or single phase
I have running as single phase. The system you mention with the pump is for drycleaners I do not use the pump so supplies are injected thru the hose. If I use it and program it for wet cleaning I would use the pump.May use it that way for drapes and Cubicals.. they look much better wet cleaned and I can do a charge back for major $$$.
