230V Land and AFCI
I think that devices as stand alone breakers are virtually unheard of here!
I have read the paper you posted and their purpose is interesting but since by law all the circuits must be double insulated, it isn't necessay as there isn't any possibility for a cable enclosed in an insulator tube buired in plaster to get fire.
You have the line, neutral and ground PVC coated wires, then a plastic cable tube that contains them and, in masonry or reinforced concrete buildings, like 99% of what happens here, everything is buired in plaster.
Typical installation have, at least since 1968, because it became mandatory (but it was used even earlier) the "salvavita", "lifesaver" a combination of magnetic thermal breaker and GFI.
So as I said I have never seen a fusebox in all my life!
Anyway, returning to the AFCI, I think that with the double insulation it is unecessary, also thermal magnetic circuit breaker serve the same purpose at it as should a sourge happen beteen two cables the magnetic part of the breaker would swich and if there was an over current sustained in a longer time the thermal part would cut off. Anyway, I have to add that it says AFCI prevents fire due to deteriorated live to live insulation. Since here there is only one live cable, the GFI is enough as every fault, even a 30mA or 10mA leak will be detected and the circuit cut off. Should the live cable be punctured, say by a drill, or by hanging a picture, the GFI would trip immediately as there would be a current leakage. Either via the drill needle, ground cord and wall or via the picture holder and needle in the wall.
Maybe that devices are famous in the USA because of the variety of services you can get in a house like live to live 220V or 208V phase to neutral, 120V and the lack of standard double insulation?
I'd like the pyrolitic self cleaning oven istead of the catalytic one but it isn't available in black and besides, it would be too expensive at more than 1100 euros! This onven is already on the expensive side at 756€ even if we're getting the 15% discount as we're getting 5 appliances there.
The former oven was the catalytic kind and we never had problems in 30 years, so I guess this one will do too.
Here's the link to the pyrolitic oven in glass and stainless steel:
http://www.smeg.it/Catalogo/Product/SCP112-2.aspx?Req=14810801
http://it.wikipedia.org/wiki/Interruttore_magnetotermico
