Let me know if anyone is interested in me posting continued progress on this. I am having alot of fun and thought I would share it. This surmounts antique washer enthusiast's big issue of dead controls and no new parts available.
I found a 1947 Bendix washing machine around a year ago and was fascinated as a water/wastewater process design engineer, particularly on the electromechanical controls. So I knocked in a set of new tub bearings, replaced my hoses and set to work reverse engineering the wiring diagram and timer on the Bendix. My original timer does work, but looks and sounds crusty, particularly the non servicable motor so I figured I would record what it does while it still does it. I was dumb enough to run a load of cloths through it without bolting it down and got a thorough ab workout keeping it on the ground while under the original timer wheel power. I did rebuild the timer as best I could first by cleaning the gear box and polishing the reed switches.
Once I determined my machine actually worked. I started building a new control head that will "directly plug in" to the wires in the back of the machine with no more "rewiring effort" than pulling the bullet plugs out of my original timer and into my new timer wiring harness. In the finishing stages of completing it. It is arduino microcontroller based but interfaces with the original washer. Waiting on a few parts to wire up the line voltage side, but I did finish my programming and wired the low voltage side and the brains are online and clicking the right relays at the right time.
I built this head to look like it could have been made in 1947. The new 120 volt power cord will go to my control head and a wire harness with a large rubber amphenol plug will send juice to the washer. Left to right, I have a power switch, cycle select knob which waves the needle on the volt meter (I will paint the cycles on the dial face when I am done), start/stop button, and a feature I added: a switch to allow the machine to continue on its own from the soak to the wash cycle. Indicator lamps on the left show whether the machine is in "set" or "run" mode. Indicators to the right show whether the machine is in "Soak" or "Wash". I also programmed my control so it will hold the volt meter pegged to the right to indicate "finished" after completing the requested cycle. There will also be a hot/cold selector switch added just below my volt meter. When in run mode, the arduino advances the needle automatically across the volt meter, much as the original timer wheel clicked around while running, in 45 second discreet intervals.
